fan belt issues
  • Thread starter Thread starter DissFigured
  • Start date Start date Oct 31, 2005
DissFigured
320
Dallas, TX
Oct 31, 2005
  • Oct 31, 2005
I put in a new alternator and for some reason, I am having issues w/ the belt. It is the same model alt as the one I removed wit the exception that the new alt has only room for one belt whereas the old one had room for 2.
when I start the car, the main wheel spins, the fan stops and goes, and the Alt does not spin at all. I get these results wether I give it no slack or the 1/2 inch recommended in my manual.
Any thoughts or suggestions?
65 289 by the way no p/s no a/c
2nd Mustang
2,488
Southern California
Oct 31, 2005
  • Oct 31, 2005
Is the belt the same old one or new one? If the belt is glazed over it won't grab. With the engine on, try holding a bar of soap on the belt where it contacts the pulleys. Becareful and don't push too hard on the soap but hold the soap firmly, or you'll cut your hands up. If the belt start grabbing the pulleys, then your belt is worn, or maybe you got some grease on the pulleys/belt during installation.
DissFigured
320
Dallas, TX
Nov 1, 2005
  • Nov 1, 2005
I will try that.
Is is possible that the groove in the wheel on the alternator is wider or deeper than the other. It sems like the belt is getting pulled into the groove tighlightly causing it to bind rather than being pulled around causing it to turn.
Also, is it possibly to pull the wheel off the old alternator and swap it onto the new one?
K
KC Hawg
Smithville, MO
Nov 1, 2005
  • Nov 1, 2005
yep, just put an impact wrench on the big nut and swap away!
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
For Sale Hogans Racing Intake manifold for SBF
  • Bullitt347
  • Jun 7, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 8, 2026
Qtrhrse23
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
