Fan Problems Please Help
  • Thread starter Thread starter qbancrzyboy
  • Start date Start date Mar 6, 2006
Q
qbancrzyboy
  • Mar 6, 2006
I have 95 GT and im having problems with the Fan, In idle the fan turns on ok. The Fan wasn't turning on at all. So then I had a mechanic over and he changed the A/C computer and my fan started working again. But now the problem is the Fan decides to turn on whenever it wants. In idle speed it turns on a little bit over the by the M in normal and when its running it goes even up to L. Please Does anyone have any idea of what might be going on?
HISSIN50
34
129
Mar 6, 2006
  • Mar 6, 2006
Welcome to the boards.
More clarification will help. You dont have a separate computer for the A/C. You are probably talking about the CCRM (a black box next to the radiator overflow bottle). It houses relays to control your fan.
If you paid to have this repaired, I would take it back because it sounds as though something was not done right.
Absent that, I would get the fan to turn on for no reason at idle. Then check for 12 volts at Pin 14 on that CCRM (Using your DMM, not a test light). And if the fan is on and there is not 12 volts at pin 14, see if Pin 17 shows ground (resistance).
That's where I would start, given the broad nature of the issue.
An alternative, assuming the fan motor is in good shape, is to install a stand alone fan controller (a Dc Control unit would work well) and circumvent the issue that way.
You could also install a manual fan switch to make sure the fan comes on. I would still seek a long-term solution, but that would work for a little while if you really watch the gauge.
Good luck.
mustangsally93
281
Omaha,NE
Mar 6, 2006
  • Mar 6, 2006
maybe a ground......... but thats just my 2 cents
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • dan50
  • Jul 18, 2026
dan50
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
