My cooling fan has stopped working. I have replaced my CCRM prior with a new part from the dealer (about 4-5yrs ago at 10-13k miles 20k tops). Went and replaced the cooling sensor switch as its just easy and cheap. the fan is not responding at all. I am trying to test if the CCRM is sending power to the fan or not to see if the fan is dead.
I have been trying to test the CCRM and can get 0 response from the volt meter. I have tested the volt meter with a 9v bat to make sure I was just not being stupid. I can not get 12 anywhere by any means. I have tried the key on, key off. I am using the information provided by hissin50 at 94-95 Mustangs Electrical CCRM - Mustang-Tech.
I have checked all the underhood and underdash fuses and none are bad.
Fuel pump is fine and I hear the CCRM clicking when I look for 12v with the key on. I have tried pushing the pins into the wires at #1, 2, 14, into the back of the harness were the wires go into the block. with the meter just reading 0.00?
I am going to see if I can get any voltage at the plug for the fan itself with the car running at temp. If I get 12v that way I am replacing the fan.
Any tips as I should be able to test the CCRM. I am about to just bypass the CCRM totally as frankly if it is the CCRM I am not buying another one if its only going to last less than 20k miles.
