Well, I have my truck apart today ... so I was forced to drive the Stang (I know ... shame on me) to go get the part I needed.
Temps. were hot today and I was creeping past 195* on the road and some around 205*. So I flipped on the high speed fan switch that I installed a long time ago and let her get back down to around 180* -ish. Well, once I flipped the switch off, the car stumbled for a split second, I saw the speedo needle jump way down, then back up. This all happened like instantaneously. Almost too fast to see it happen. While this happened, my ABS light came on for a second or 2.
So ... I did it again (flipped switch on and back off). It does it again! I did this several times and this happens everytime I cut the switch off.
Is it something crazy going on with the ABS stuff or what? I have not tried to pull codes yet ... just seeing if anyone may have had this happen to them.
I also like to have some sort of clue where someone's head was when they reply to my threads. Helps with those ideas from left field.
