Fastest gone in stang?
im nuts
my 03 cobra is the fastest thing i ever drove.brand new going south on the garden state parkway ,was running with a seleen,had to find out?it only takes about a min to get to 159.it was a blast.scary going threw traffic. i moved to san antonio so my cobra wont rust out,highway 10 here is 80mph just outside of the city going west.its like an autobann 120 to 150 is common ,,ok im a speed freak
Absolutely Not true idk with gears and changed speedo gear , but my stock 3.08 GPS verified has a top of 1-2 mph difference on all speeds from 0-120 mph verified , idk anything beyond that i dont have high speed rated tires to do more, but this cars have the most acurate speedo i have ever seen on a car.
then you sir have 1 freak of a speedo.
i have personally seen speedos on $100k+ cars be off as much as 10% at 80mph--it gets worse the higher it goes. bmw even states that a 15% difference is normal and there is nothing to fix that.
Yep. when tires get worn down, that will throw the speedo off. The slightest change will throw it off.
I've had mine at about 125 on the freeway. It had plenty left but i won't take it higher than that on public roads with our crappy stock brakes. With 3.08s or 2.73's i think you could hit 175+ if you had the power, i barely break 2k rpm going ~85.
just cause you have the gearing to go 175 i dont think its possible with our suspensions, we would float right off the road
I hear ya. However, just because a car is $100+k does not mean the spedo is going to be more correct than any other car. Last time I got pulled over by the copper in my 5 series, he was dead on accurate, lol. :shrug:
To the person that said he was able to do 155..was that with the mods in yur sig? (closed course of course!!)
heh heh heh
heh heh heh
Actually, I think that is an A-36 Apache. North American's first attempt at the Mustang, but with the Allison engine, its high altitude performance was lackluster. Therefore it was used mainly as a ground attack aircraft. It wasn't until the Rolls Royce Merlin engine that the aircraft was designated the P-51B and it became an excellent fighter.
Edit: Upon further research, that aircraft has british markings in which case they referred to it as the Mustang Mk I as the Americans called it the A-36A. You were right.
