  • SN95 4.6L Mustang Tech
Few basic questions
  • Thread starter Thread starter Coolman532
  • Start date Start date Mar 4, 2004
Coolman532
49
San Jose, CA
Mar 4, 2004
  • Mar 4, 2004
What does a shorthrow shifter do?
What does it mean when someone says its 4.6 liters, what does that have to do the the mechanics of the car? Same thing when some one says 302 cubic inches, what does that imply?
What is the purpose of a carburator?
Thanks.
A
AquamanCHS
122
N. VA
Mar 4, 2004
  • Mar 4, 2004
1. The 'throw' of a shifter refers to the distance your hand travels from one gear to the next... so a short throw shifter minimizes this distance to provide faster shifting.
2. liters and cubic inches are units of volume... so what people are referring to when they say '4.6 liters' or '281ci' is the capacity of all of your cylinders combined, also known as your engine's displacement. so if you filled up all your cylinders with water, in theory you should have 4.6 liters total... FYI, a 4.6 is about 281 cubic inches.. the 5.0 is about a 302, etc
3. in order for combustion in your cylinders to take place you need gasoline mixed with air and a spark... the gas/air mixture is created by your carburator.. newer cars have fuel injectors
(i hope i got all this right.. i'm a bit of a car newb myself )
daver01
396
Lexington, Ky
Mar 4, 2004
  • Mar 4, 2004
i have never heard any of those used in automotive discussions?
Coolman532
49
San Jose, CA
Mar 4, 2004
  • Mar 4, 2004
What do you mean you never heard those in automotive discussion. I read it all the time in magazines and stuff. I hear people talk about it.
blk2003GT
108
Las Cruces, NM
Mar 4, 2004
  • Mar 4, 2004
Yeah, everyone thinks all mustang GT's are 5.0's.
everyone talks about displacement
Camaro/TA - 5.7
Ford GT - 5.4
EVO - 2.0
Corvette - 5.7 (soon to be 6.0)
Civic - 1.7
Integra - 1.8
350Z - 3.5
RX-8 - 1.3
To get cubic inches from liters just multiply by 61, to go from cubic inches to liters divide by 61.
Coolman532
49
San Jose, CA
Mar 4, 2004
  • Mar 4, 2004
One more question
What is push rod? i Know camaros and old mustangs have them. What advantages to these engines have over SOHC and DOHC.
blk2003GT
108
Las Cruces, NM
Mar 4, 2004
  • Mar 4, 2004
Pushrods are used in older engines that are called OHV (over head valve), the pushrods open the valve when they are actuated by the camshaft (single camshaft in the Vee of the block. SOHC is actually better technology than OHV (pushrod engines), and DOHC even better. It just seems that pushrods are better when you compair the LS-1 to a modular GT motor, but the Camaro/TA engine has more displacement and higher compression. I'm by no means a engine guru, but I think thats all right?
4.6Mustang35th
11
  • Mar 4, 2004
Yes, the dohc and sohc can also rev higher then pushrod motors. But pushrods typically produce more tq at a lower rpm then dohc and sohc, its all about revs
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
