Few Problem's With '89 GT
  • Thread starter Thread starter TwoToneHatch
  • Start date Start date Apr 13, 2008
TwoToneHatch
170
New Jersey
Apr 13, 2008
  • Apr 13, 2008
Hey All,
I am having some problems with my '89 GT and hope I can get some help.
When I first fire it up the idle drops real low where it almost shuts off and then shoots up to over 1000rpm and then either surges a little or goes back to normal.
Secondly My Check Engine Light turns on sometimes after the car warms up but then goes away only to come back on again.
My gas mileage has also dropped significantly It just drinks gas now.
I gave the car a tune-up last summer and have since cleaned the throttle body and IAC . I am about to order new o2 sensors(the car still has original ones) and EGR valve (because mine is buzzing). Will the new EGR and o2 solve my problems or is there something else wrong I should address.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Apr 13, 2008
  • Apr 13, 2008
if this is happening on a cold start it wouldnt be the o2s causing the problems.
the o2s only function and give the EEC feedback during closed loop mode (up to temp and no hard faults within the EEC)
is your CEL a solid contant light, or does it go on and off.
go to the parts store and use their code scanner, it will scan and tell you what the code is.
sounds like it could be the IAC giving you fits, check the codes and if it is, pull it off and clean it out with carb cleaner and blow it out and try.
before doing anything i would unhook the battery for a while to clean the codes and run it and let only current problems register before scanning codes. you may have saved codes from before or something i am not sure if you have.
also before you try and make the repair, like cleaning the IAC or something, be sure to unhook the battery again to clear codes so you will be know if it fixed it or not.
TwoToneHatch
170
New Jersey
Apr 13, 2008
  • Apr 13, 2008
So the O2's and EGR are not at fault? I'm guessing that any major parts store will have a scanner (like autozone) ? What about my poor gas mileage? I haven't changed my driving habits or anything yet now it just drinks gas like hell.
90blacknight
136
Apr 13, 2008
  • Apr 13, 2008
Most autoparts stores should carry a scanner. Pull the codes!
TwoToneHatch
170
New Jersey
Apr 13, 2008
  • Apr 13, 2008
Ok guys thanks alot for the help ! :SNSign:
I'll go get the codes pulled as soon as I can this week.
corvetteguy
71
  • Apr 14, 2008
A clean MAF will help the idle.
Summer gas will help the mileage.
The best I ever got on my 89 GT was 20.
In winter I ran less than 15.
svtpower
257
Wisconsin
Apr 14, 2008
  • Apr 14, 2008
tune up
What exactly did you do for the tune up?
Did you do air filter, plugs, wires, cap and rotor?
What are you running for exhaust?
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Apr 14, 2008
  • Apr 14, 2008
Make sure your vacuum lines are all in place and undamaged. Vacuum leaks could cause a rich condition and therefore, poor gas mileage.
mustangfan1990
505
Lenoir, North Carolina
Apr 14, 2008
  • Apr 14, 2008
he said that the CEL came on when the car warmed up I would say the gas issue is the o2s
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Apr 14, 2008
#10
  • Apr 14, 2008
  • #10
not sure if its the EGR or not, but the o2s wont cause problems during a cold start and warm up in open loop.
if your CEL is on when the car is warmed up then the o2s may be a fault. causing poor milege. without the feedback from the o2s the EEC is guessing in the dark
your local oreilys or autozone should let you borrow the scanner to take out side and scan the codes. just plug it into the diagnostic plugs under the hood and if its the good scanner it will tell you what to do.
HISSIN50
34
129
Apr 14, 2008
#11
  • Apr 14, 2008
  • #11
Stop guessing and pull the codes. It takes 5 mins and requires but a piece of wire.
Good luck.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
