figured out my rough idle!
  • Thread starter Thread starter cenok is family
  • Start date Start date Jun 30, 2007
cenok is family
1,409
69
79
Norman, Ok
Jun 30, 2007
  • Jun 30, 2007
i was using the NON HO firing order...
would driving it 10 miles like that hurt anything?
1991vert
1,103
Ludlow, MA
Jun 30, 2007
  • Jun 30, 2007
it would just drive/idle like butthole
BLOWN 5.0 FOX
213
NORTH SHORE MA
Jul 1, 2007
  • Jul 1, 2007
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Jul 1, 2007
  • Jul 1, 2007
dont feel stupid...i did the same thing.....
1991vert
1,103
Ludlow, MA
Jul 1, 2007
  • Jul 1, 2007
i had an injector unplugged for a few weeks and couldn't figure it out
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jul 1, 2007
  • Jul 1, 2007
things like that happens..
turp23
73
Louisiana
Jul 1, 2007
  • Jul 1, 2007
what is ho firing order, and how do you know to use it?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 1, 2007
  • Jul 1, 2007
This doesn’t prove that the block is a HO block. Some trucks evidently use a HO firing order
with a low lift cam. However, it will definitely prove that a block can’t be HO because the firing order is wrong.
Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
A
Resolved 302 still running after turning off ignition
  • AlexM556
  • Nov 14, 2026
Classic Mustang Specific Tech Nov 15, 2026
AlexM556
A
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
