Well, after a year of having the stang i'm finally getting some 3.73's. I got quoted by a shop and they said it'll be $420 including the gears and all fluids but not the Speedcal.
Anyways, the GT is at abit under 56k miles and i'm just wondering what all needs to be replaced when installing the gears since the diff is open anyways?
I know its all new shims, gear oil, speedcal to correct the speedo, friction modifier and stuff, but should i get the master bearing kit and change all of those out as well or should they be fine since im only at 56k? Also, would a t-lok rebuild kit be necessary at this point? I don't want to be stingy, but i also don't want to spend freakin $800 on a gear swap just because i replace everthing in the world.
Those of you that have done it, did you just buy the gears and replace the old shims with the new ones and call it a day? Thanks
