I am finally ready to pull the trigger and purchase a 347 stroker long block from CHP for my 68 Fastback and had some questions I hope you guys can help with. My current engine is a stock 302 and I plan to be installing a T-5 tranny along with the new engine. The CHP 347 has the following specs: AFR 185's, roller cam (not sure of the detail specs) and valve train, 9.5:1 comp ratio, advertised 400 HP. Here are my questions:
1)The flywheel on my 302 was resurfaced approx 1,500 miles ago. Can I resue this on the new engine? If not, what type of flywheel do you suggest and where to purchase?
2)What is a good damper to use on this setup and where to purchase? Primary use is street driven.
3)Current 302 has an almost new Holley 600 CFM carb vacuum secondaries (model 4160 I believe). Will this carb be ideal for my new engine?
4)Would the Edelbrock RPM Air Gap intake be a good match for this setup? Any clearance issues running a stock hood?
5)Looking at the Hooker Super Comp's with ceramic coating. These appear to be a well used standard for a lot of guys, please confirm.
6)CHP offers the old style timing cover for $63 that I plan to include in my order. Any other considerations for this engine as it is going in a classic stang? Specifically, oil pan/pickup tube?
I know this is a lot of questions, but I really want to make as few mistakes as possible with my choices. thanks in advance.
