Finally got my car tuned
It was tuned by Atlanta Chassis Dyno today, which by the way the people there are awesome, they did a great job. It made 315hp@5,600 and 305tq@5,200. It needs some new o2 sensors though its not running too great right now, but it still has a lot more ass than it did.
Nice HP number but with peak torque at 5200rpm, the engine will feel very soft at low rpm. Easy to see why with your H/C/I combination being aimed at high rpm performance. The HP number should be peaking at higher rpm though so I wonder if the valve springs might be too weak causing the valves to float above 5600rpm. Can you post the dyno sheet?
new dyno #s 320 hp and 311 tq.
car wasnt running to great when i got it back and they told me it needed o2's and i put those in and didnt do crap.
took it back and the engine coolant temp sensor was shorted and they dynoed it again and it made more power and ran a lot better so im happy!
Rebuilt bottom end, comp 282hr, AFR 185s, Comp 1.6 rr's, Edelbrock Performer II intake, 24lb injectors, 70mm tb, 70mm egr, 3550, BBK shorties, Pypes catted X, Magnaflows, Pro 5.0 shifter, 3.73s, u/d pullies, K&N, MSD ignition.
