Finally got my gauges installed. How do these reading sound?
The Shape
2,224
East ARKANSAS Delta
I put in mechanical phantom gauges (oil press. , water temp. , volts) I have a 180* thermostat and the car runs around 185 or so while cruising and on the few warm days we have had it would climb close to 190* while idling for a while.
Oil Pressure hits right at 60 p.s.i cold. Fully warm it cruises at around 48 at 2k rpm's. Hot idle is a little scary though it sets right on 20 p.s.i. I am afraid if it is hitting 20p.s.i at hot idle now with the highs in the 70's it will dip to low this summer when it gets really hot out. This is with 10W-30 , how worried should I be about that pressure???
above 8psi hot idle is sufficient, based on the Ford spec
James, I'm glad to hear it's all completely finished and buttoned up. That's all I wanted to say................
You know my thoughts on all this, so I wont bore you. :P (Steve, you and I agree about upping the viscosity in the summer). Then again James, you do have that new motor technology to consider (the replies on that thread stuck with me. Funny stuff).
Enjoy - you did a real nice job on that install - I dig the plate. :nice:
Yeah JT I had almost forgotten that thread. But yeah I am fine with 20 psi and figure if I just up the viscosity before summer it should be cool. As soon as I bump the throtle it shoots back up so I think the higher viscosity will get me quite a few more miles out of my mill.
