FINALLY!! She runs GREAT!!
CManT1914
3,172
Killeen, Texas
Okay, it turns out I DID have a vacuum leak, at least two.
One was where the 3hose connector for the vacuum lines that run to the smog, egr, and upper intake. If anybody remembers, that harness had fallen against the header a while back and melted most of the lines. I had thought I had fixed all the holes, and capped them good enough, but when I went to remove the harness today to clean up the engine bay, I found all three lines had holes in them from where they had melted. The red line that runs to the upper intake had come off of the harness completely. I removed that, replaced the red line (with the green one which was still good, lol) and capped off the others and that made a big difference.
The second one was the front and rear seals on the lower plenum. They were pushing out and leaking oil big time. I'm sure that was a vacuum leak too. I ended up just using a big bead of RTV instead of the actual seals (recommended by quite a few mustang guys).
Anyway, I put it all back together, and she didn't fire up. I knew it must have been timing, it only took two tries and she fired right up and was running like a champ! Unfortunately, I ended up shredding my belt (power steering pulley was out of alignment), and had to go get a new one. I got one one size bigger, and this one was just a little to big, and when I revved up the engine, the entire belt came flying off. :eek: I ended up putting my underdrive pulleys back on, and they took up the slack perfectly. :)
So here was the moment of truth. I pulled out of the garage to take it for a drive, and GOD she just RIPPED the tires off through 1st and 2nd (didn't hit it hard in 3rd, I was in town). Here's the best part!: I ended up shaming a Z28! :banana: :banana: It was the greatest moment of my life. lol
All in all it was a pretty good night. I still have some tuning issues, the idle drops real slow, and it's still running a little rich. I need to try messing with the afpr since the last time I did it, I had a big vacuum leak. Then I gotta mess with my injector slopes a little and a few other things and I should be good to go!!
Anybody visiting the Killeen/Ft. Hood area had better watch out!!
:banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana:
95WhiteVenom said:
Sweetness dude. Get that thing dialed in good and I want to see some Dyno numbers all the hard work and $$$$ has finally paid off.
Yea one of these days I will hopefully get to a dyno to see what she's putting down.
91LX_5L said:
how can I test for vaccume leaks? I think I might have one that might be the sourse of my power loss.
You can take a can of carb cleaner and while the engine is running spray it on all the likely places (lower intake manifold, upper intake, throttle body etc.) and if the idle raises then you know it's a vacuum leak there. Cus it sucks in the carb cleaner through the leak and burns it. Unfortunately my vacuum leak was inside a piece of loom where I couldn't get to it with some carb cleaner, lol.
stprorolla49 said:
HOW!!!! i remember around march or so when i recommended them to you, and you got all excited, and now they are used up??? wow you must do a lotta burnouts :D you gonna grab some 315 nitto dr's??
Yea they still have some tread on them, but not like they used to. The HTRZ's don't last as long as the HTRZII's. They are still decent though. I think I am gonna roll up on some Nitto's next. I really like the BFG drag radials, but they wear to quickly for my taste. I drive to much eceryday to justify buying them anyway.
hey sorry to bother you but i have a 95 gt put a gt-40 motor with x heads and a e-cam,track heat manifold,65mm bbk throttle body, c&l 76mm maf cold air intake, 24lbs fms injectors and just got a custom chip burned it is still real doggish out of the hole and it seems like it bounces rev limiter @ 5500rpm which should not be there do you have any suggestions could it link to my fuel pump filter or pressure oh yeah and it is real hard to start and keep running. i forgot it has a header leak could this have anything to do with it? it is getting fixed tomarrow
trelz4, start a thread to ask your question. YOu will get better response that way. BTW, a header leak could cause significant performance issues (if large enough). And yes, your fuel pump may be an issue if it is stock.
