Finally went 12's n/a
Here is my 2 best passes from the other day. first was a 12.7x, then a 12.6x, and 2 12.5x's
http://videos.streetfire.net/video/DDD8679F-F734-407E-9018-3C9CDB85EFFE.htm
and
http://videos.streetfire.net/video/B9EB42FC-BAC2-41B2-AA05-5F17881BBC22.htm
Timeslips
mods are
Vt Stage 2 Cams
-Densecharger
-C&L Plenum
-Accufab 75mm T/B
-Bassani cat back
-Mac Prochamber
-Diablo Predator
-MM caster/camber plates
-Eibach Drag Launch Kit
-Tokico Illumina
-Ford Racing 4.10s
-Steeda Tri-ax
-Steeda full length subframe connectors
-Detriot True Trac
-Moser 31 spline axles
-Weld Prostars(15x5 up front 15x8's out back)
-tumas clutch set up
-fidanza alum flywheel
-mac long tubes
-steeda pullies
-pa performance mini starter
-26x11.5 et streets
3350 weight
and
Timeslips
mods are
Vt Stage 2 Cams
-Densecharger
-C&L Plenum
-Accufab 75mm T/B
-Bassani cat back
-Mac Prochamber
-Diablo Predator
-Tokico Illumina
-Ford Racing 4.10s
-Steeda Tri-ax
-Detriot True Trac
-mac long tubes
-steeda pullies
-26x11.5 et streets
3350 weight
. And update sig
