Couple peple asked to see the graph so here it is
car still needs a tune note the a/f very rich where peak tq is
mods are
Vt Stage 2 Cams
-Densecharger
-C&L Plenum
-Accufab 75mm T/B
-Bassani cat back
-Mac Prochamber
-Diablo Predator
-MM caster/camber plates
-Eibach Drag Launch Kit
-Tokico Illumina
-Ford Racing 4.10s
-Steeda Tri-ax
-Steeda full length subframe connectors
-Detriot True Trac
-Moser 31 spline axles
-Weld Prostars(15x5 up front 15x8's out back)
-tumas clutch set up
-fidanza alum flywheel
-mac long tubes
-steeda pullies
-pa performance mini starter
-26x11.5 et streets
also 2 pics from the track the other day
mods are
Vt Stage 2 Cams
-Densecharger
-C&L Plenum
-Accufab 75mm T/B
-Bassani cat back
-Mac Prochamber
-Diablo Predator
-Tokico Illumina
-Ford Racing 4.10s
-Steeda Tri-ax
-Detriot True Trac
-mac long tubes
-steeda pullies
-26x11.5 et streets
haha
