Well the deadline of the starting was today , and it was a little late but i decided to go on, so after prime the pump it started no hesitation , no nothing everything went so perfect that was hard to believe, the tweecer was pure gold on the first start, idled exactly at 1500 then lowered to 800rpm as programmed, I couldn’t log the first startup since i was like crazy checking any leak or any thing that could indicate something bad, after the first 4 mins like a crazy man with a lamp checking the engine everywhere, i calmed a little and waited to temp go stable, then turned of , checking leaks again, then the 2nd start , the lifters were still a little bit noisy but they where calmed after a few mins more and a little rev up to 2k, i started to log with the tweecer and the karmfs started to move a little as time passed idling, well the only problem i found is that the aero motive fpr never reached the 39 lbs of pressure , i started to move it but i cant get the 39 psi , the most i could reach was like 34 psi, so the tweecer started to show that the karmfs would go up to 1.250
i guess is the damm fpr , well its 12:45am and the neighborhoods were not pleased with the concert so I stopped after like 15 mins of idling and revving no more than 2500. i will start tomorrow to see what is happening with the fpr and log again.
Long post as always but I would like to really thanks all the :SNSign: for all the help , posting on my threads and the old posts on all the h/c/i process really thanks to all of you b/c without any of you I could not get this done.
:SNSign:
:SNSign:
I will update tomorrow with more time
:SNSign:
:SNSign:
and only stays on a very short time. Couple that with the HCI = hoooootttttt!!
