finding LCD code scanner jrichker
Glaze
133
Gainesville, GA
"For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/deta...ption.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35"
Checked Wal Mart in GA area and only code scanner they have is an OBD2 for $90. Have you actually located this engine scanner in a FL Wallyworld?
Also is there a code scanner that will scan for airbag codes? Interested in a unit under $100 if possible.
Hey bud.
They also dont have 'em around here. I think CSK (Checker) does have that reader however. And Midway Auto Supply (online retailer) and Ebay have units in the same price range.
For air bag stuff (if you need it ASAP), see S&2B's site here .
Good luck bud.
ive seen that scanner at advanced auto parts, all their electronics and gauges are actron, my fp gauge and compression check gauge, voltmeter and remote starter are actron, and they have tons of other stuff, the code scanners, vacuum gauges, etc. if you have an advanced auto parts around there check it out, theyll have actron parts.
Thanks guys for the input.
I will be purchasing the Equus unit to check engine codes only.
Hissin, thanks for the reply and useful site. But unfortantely it doesnt have any explanation on the 93 year. I am not going to assume the 92 year is the same off the bat. Reason or you guys gonna make me study wiring diagrams?
I had a clock spring go bad on me that started the Air Bag light. Replaced the clock spring and still have the Air bag light. And yes with the battery disconnected for over 4 hours. I am assuming that i must delete the code in nvram memory? How? With a specific scanner such as mechanics have? I will see what the onboard monitor is posting if any but i believe that it stays on continous which on the web site states the onboard diagnostic monitor is disconnected or inoperative. Possible bad clock spring shorted out monitor?
Car is 93 4 cyl auto in very good condition. No alarm has been installed. Wiring in good condition.
I was the one that said to check Wal-mart. :)
My local Wal-Mart and Sears USED to carry them. But, I haven't seen my the scanners in my local wal-mart or Sears in about 6 months. My guess is that they weren't selling enough scanners for the 10-20+ year old cars. :)
I have not found a readily available scanner for airbag lights. I had to have the dealer reset mine.
Apparently the airbag control knows when voltage is low or is cut off in anything other than the approved sequence, which is with the car off, and then pull the battery cables.
I pulled the airbag fuse by mistake and it set the light until the dealer turned it off.
Whoa...
Are we talking about an EEC scanner or an airbag/ABS scanner????
For pre-96 Stangs, you can scan ONLY the EEC. The 94/95 Air bags have a "reset diagnostic connector" if the battery gets changed, or the baterry voltage goes low.
The 94/95 Stangs with ABS need an ABS scanner that can read 94/95 Ford Mustang ABS.
For pre-96 Stangs, the air bag and ABS will blink the light (air bag, or ABS light) for an error code. No need for a scanner.
For 94/95 Stangs, the air bag diagnostic controller needs to be reset when the battery is changed. I have the info on my web site.
For air bag info, see:
For Mustang Air Bag info, see:
http://www.veryuseful.com/mustang/tech/airBag/
was talking about eec scanner and had a seperate problem with airbag and didnt know if there was a low cost scanner that would do both.
i believe the fuse is blown which powers the airbag system causing the continued code 12.
appreciate the heads up stang2birds
