Well, Sunday we finished my H/C/I, so my car is now equiped as you see it in my signature. I drove it home, but monday morning I started it and all my oil came out. I checked the filter, and it was loose. I retightened it, put more oil in, and headed for school. Within ten minutes my car was overheating. Coolant was spraying out of my lower radiator hose, but the hose wasn't broken at all. It took me an hour to limp the car 15 miles to my mechanic's garage. I installed a new 195* stock Tstat,thinking that the 180* one I had put in could be defective and stuck, but that didn't help. I went to remove the oil filter after loosing another load of oil, and it broke in half right on the motor. I finally got it all off the block, and figured that maybe it was a defect so I got another filter. Same result, spewing all my oil. I took the filter off and brought it into the mechanic's shop. We looked at it and realized it had blown up from too much pressure. The part that screws into the block, where it's concave like a bowl, had blown out and become a dome. After some calls, we came to the conclusion that my oil pump was broken and stuck on max flow. Apparently inside the pump there's a spring that compresses as the pressure goes up, limiting the pump's flow rate. My spring got stuck, so my oil pump was going full flow all the time, blowing up the filter, and pissing out. We changed it last night (that sucked a big one), and the oil filter explosion problem was solved. Now my only problem is that the car is running a little hot. I left it at the shop overnight because we're installing a FRPP clutch tonight, and my mechanic took it for a ride this morning. He said the temp was holding around 200* I know I could use a new radiator, as my old one is pretty beat up, but if anyone could trouble shoot this heat thing for me, I'd appreciate it. I plan on getting a new 3 core rad. asap.
PS- other than this crap, the car runs awesome, has tons of power, sounds mean as hell, and generally gets me all excited
