Finished the install...
  • Thread starter Thread starter blacknblue2002
  • Start date Start date Apr 11, 2006
blacknblue2002
159
Va Beach, Va
Apr 11, 2006
  • Apr 11, 2006
...last night I finished the mongoose install. I was extremely pleased that the car started on the first try...I was worried....anyways....it seems that the car idles pretty rough right now...I've been told to give it a while so that's what I'm gonna do. During normal driving there's not a noticeable difference in power, but I do hear the slight whistle every now and then coming from the Vortech SQ.
Are there any things that I should be looking for as far as hoses, tubes that are proned to leaking? I have no oil/radiator leaks as of yet, so that's good. I am afraid that the seal isn't very good around the IAT on the discharge of the supercharger. Would this cause huge problems/power loss. I'm afraid to get on the throttle too much until the idle cleans up. I will post pics within the next couple of days....i put on new badges, and waxed the car while it was in the garage during the install.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Apr 11, 2006
  • Apr 11, 2006
uh man you need a dyno tune before you go rompin around, thats probably part of the reason its idling rough...
G
GT02MG
49
MD
Apr 11, 2006
  • Apr 11, 2006
He never said he was romping around on it...sounds like to me he was taking it pretty easy.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Apr 11, 2006
  • Apr 11, 2006
well in either case he needs a dyno tune to get everything working properly, so he can then get on the happy pedal
G
GT02MG
49
MD
Apr 11, 2006
  • Apr 11, 2006
no doubt
Mossberg
ATL, Shawty
Apr 11, 2006
  • Apr 11, 2006
The Mongoose kit comes with a custom tune. All you need to do is get the car on the dyno to check A/F ratio and that's it.
VPStang
346
bHAM, alabama
Apr 11, 2006
  • Apr 11, 2006
NEGATIVE. If you got a mongoose kit, you don't need a dyno tune. you just need to run it on the dyno to check your a/f to make sure your not running lean. Chances arer, your tune is gonna be dead on. The idle problem should go away, and you'll notice that it idles slightly higher than it used to when stock. If you experience any surging while driving, it means you probably need to upgrade the BPV barring any leaks in your plumbing.-- most people upgrade to the mini race BPV.
Mossberg beat me to it...
AmBo
1,027
New Jersey
Apr 11, 2006
  • Apr 11, 2006
How was the install? I'm looking into this kit in a month or so (once the tax return money comes back).
Firemanz
Only you can prevent Forest Fires!
4,105
San Antonio, TX
Apr 11, 2006
  • Apr 11, 2006
Congrats, you'll love the feeling of being boosted.....
Take it to a dyno, check your A/F ratio, and see what HP increase you just bought yourself.
AmBo
1,027
New Jersey
Apr 11, 2006
#10
  • Apr 11, 2006
  • #10
With the mongoose kits, the tune comes installed on teh SCT2 to just load, correct?
blacknblue2002
159
Va Beach, Va
Apr 11, 2006
#11
  • Apr 11, 2006
  • #11
tune was loaded on SCT....install was definately not the easiest thing I've ever done....but I'm nowhere near a mechanic....the worst part was coming up with all of the tools I needed....nothing major, but I barely have hand tools
The idle was still pretty rough on the ride home today...it hangs for a good bit...but it did the same thing when I first installed the 75mmTB and plenum...I don't expect it to be fixed for a couple of weeks....it'll probably gradually go away until I don't notice it at all....then I will get the A/F tested, and get some gauges
Miles
1,225
Burlington, ON
Apr 11, 2006
#12
  • Apr 11, 2006
  • #12
blacknblue2002
159
Va Beach, Va
Apr 12, 2006
#13
  • Apr 12, 2006
  • #13
PICS
okokok...i gave up on finding time to wash the car....so here are some pics of the pollen covered POS:
Engine:
http://i60.photobucket.com/albums/h13/BlacknBlue2002/c76a084c.jpg
Side Before New Emblems:
http://i60.photobucket.com/albums/h13/BlacknBlue2002/573cf659.jpg
Crappy pic of new emblems:
http://i60.photobucket.com/albums/h13/BlacknBlue2002/3726e62e.jpg
Crappier pic w/ shot of matching brakes:
http://i60.photobucket.com/albums/h13/BlacknBlue2002/780e38c4.jpg
Deryagobeetches
BennyBlown2v
1,233
Carmel, INdiana
Apr 12, 2006
#14
  • Apr 12, 2006
  • #14
Lookin good! Post numbers when you hit up a dyno
Cantslowdown
502
Mt.Home AR!
Apr 12, 2006
#15
  • Apr 12, 2006
  • #15
I want to see a vid and all so i can hear this bad boy!
AmBo
1,027
New Jersey
Apr 12, 2006
#16
  • Apr 12, 2006
  • #16
So how long did the install take you total? Did you have ANY prior experience? help? You shoulda got the MPH boost pipe too for the extra $200.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 12, 2006
#17
  • Apr 12, 2006
  • #17
Sure you got all the vacuum lines hooked up right afterwards and that they're in good condition? A vacuum leak will cause a rough idle.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
