fire wall adjuster
  • Thread starter Thread starter just4bob50
  • Start date Start date Jun 25, 2005
just4bob50
504
Pa.
Jun 25, 2005
  • Jun 25, 2005
this will sound stupid but, when i had my clutch put in i also had a new quadrant with the fire wall adjuster put in at the sametime. the mech who did a great job wasnt sure how or when the adjuster should be used. So my question is what exactly is it adjusting. Ive got about 3000 miles on the clutch and i was wondering if the throw can be changed onthe pedal with it
Vipersix
434
Clarksville, TN
Jun 25, 2005
  • Jun 25, 2005
You can adjust the "pull" on the cable with that unit. It allows a greater range of adjustment for your cable than the stock unit and actually holds unlike the stock POS. It basically shortens or lengthens the effective length of the cable so there will always be a set engagement of the pedal. I wouldn't recommend engaging too much or you'll reduce your clutches effectiveness and wear out the throw out bearing prematurely.
87TTopGT
173
  • Jun 25, 2005
If this is what you mean by "throw" you cannot chabge the height of the pedal or how far it moves. You can only adjust the tension so that there is no slack in the movement.
just4bob50
504
Pa.
Jun 25, 2005
  • Jun 25, 2005
thanks for the info
trbkrb
1,976
Houston, TX
Jun 25, 2005
  • Jun 25, 2005
Once I installed mine several years ago, I only had to adjust it a couple of times after the cable did it's initial stretch. It worked fine until the cable gave out a couple of months ago. My new one I just adjusted it once I got the car home, and it is still working fine. You might need to adjust it if the cable is not quite disengaging the clutch enough to put it in reverse without putting it in first gear first. That is a typical symptom of a clutch not fully releasing on my car. Then it is time to adjust it a couple of turns and try it again.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
