  • SN95 4.6L Mustang Tech
firewall adjuster
  • Thread starter Thread starter mustang70
  • Start date Start date Nov 19, 2004
mustang70
2,445
San Diego
Nov 19, 2004
  • Nov 19, 2004
Does anyone have any idea how this thing doesn't lose the adjustment?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33730&item=7935207540&rd=1
Turbo92PGT
746
Auburn Washington
Nov 19, 2004
  • Nov 19, 2004
Honestly man, dont get that pile. I bought the triax shifter and liked it ok, but then got a pro50 and liked that alot better. So I figured steeda crap wasn't worth the hype it gets. Then I finally got sick of crawling under my car to adjust my clutch with the BBK unit I had. Bought a full steeda one.
- Double Hook Quad -
- Adjustable Cable -
- Firewall Adjuster -
The construction quality was awesome. Really good quality pieces. The firewall adjuster comes with two places to attach it to the firewall, unlike that one, as well as a set screw so it wont change adjustments on you. Cost me 100 bucks, but I think it was worth it.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 19, 2004
  • Nov 19, 2004
Yes,the Steeda Firewall Adjuster is a great quality piece!
mustang70
2,445
San Diego
Nov 19, 2004
  • Nov 19, 2004
I was planning on going with the Steeda firewall adjuster. I'm already getting their quick ration quadrant. I was just curious how that one held the adjustment since it doesn't have a lock nut or anything.
40th GT
916
Lawrenceville, GA
Nov 19, 2004
  • Nov 19, 2004
What's the differece between the double hook and the quick release quadrant?
mustang70
2,445
San Diego
Nov 19, 2004
  • Nov 19, 2004
I think the double hook lets you adjust where the pedal sits. The quick release is supposed to shorten the pedal throw. Which is what I want.
95BLBLVert
486
Lake Wylie, SC
Nov 30, 2004
  • Nov 30, 2004
Astro Performance has a firewall adjuster and quadrant that is better than all of them. The adjuster is self-locking and doesn't use set screws or jam nuts.
http://www.astroperformance.com
twogts4us
4,188
12
79
Dunedin, FL
Nov 30, 2004
  • Nov 30, 2004
1. Whether I tighten the lock nut or not, the firewall adjuster simply will not move. I've left it loose with no movement whatsoever. That Mustang Warehouse Firewall adjuster looks just fine to me...hell of a lot cheaper than the others, and jeez, it's just a friggin firewall adjuster...just a big hollow bolt!
2. The difference between the 2 pickup and quick release, steep ramp steeda quads is so minimal it's a crime that they sell these two things as two different pieces. I've got both, held them both, back to back, and I can honestly tell you the difference is minute. I swapped back and forth and there is no difference in release points.
To adjust the release point, well, it's a combo of things. I found the best way is to be able to adjust the cable completely - at the trannie, at the firewall - and then added the maximum motorsport clutch pedal adjuster-then fine tuned it all and now the pedal sits even with the brake and the release point is about in the middle of the shorten travel. It takes some time and patience to get it right, especially after adding an aftermarket clutch.
mustang70
2,445
San Diego
Nov 30, 2004
  • Nov 30, 2004
I got the quadrant on ebay for $18. So I'm not complaining about that at all. I just don't want to have to worry about the adjuster loosening up on me.
95BLBLVert
486
Lake Wylie, SC
Nov 30, 2004
#10
  • Nov 30, 2004
  • #10
You will not loose any adjustment using the Micro-Click adjuster. Partshopper.com has them too.
Fox Clutch firewall adjuster
  • limp
  • Jul 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 1, 2025
limp
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
D
How to adjust 1994 Covertible--passenger side doesn't mate up right.
  • DPP
  • May 23, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 12, 2025
DPP
D
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
