Hey guys,
I did some initial testing last week with my new setup, a '01 GT with:
- Vortech V2 (not aftercooled)
- Anderson boost pipe
- Focus pump
- 42 lbs injectors
- TR6 plugs gapped at 0.030
- Accufab 75mm plenum/tb
- MAC off-road h-pipe
- 4.10 gear
- ET Drags on Weld Racing wheels
-> No weight saving, swaybar still installed, on stiff Sportline springs
This is a 1/8 mile track that doesn't have a very good reputation about track prep. I went there because it's the nearest (safest) place to do initial testing. The results:
60 ft: 1.74 (couldn't launch above 4000 RPM to keep traction)
1/8 mile: 7.83 @ 91.3 mph
Temperature: 88F with 70% humidity
My questions…
1) Is this good considering the setup and conditions?
2) On another track, with better prep, launching at 5500 RPM under colder weather (70-75F), do you think this is a high 11s car?
Thanks.
Regards,
Yan
- Focus pump
- 42 lbs injectors
- 4.10 gear
My questions…
Thanks.
Regards,
Yan
The more air that goes through, the cooler your inlet temps get...so instead of getting hotter, they will get cooler (= more HP) .
