  • 1994 - 1995 Specific Tech
first gear lock out?
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Dec 11, 2007
1 of 2 Next Last
DDSTANG94
465
FRASER, MICHIGAN
Dec 11, 2007
  • Dec 11, 2007
ok sometimes when am at a light and my car is in neutral and i go to put my car in first gear, it wont go in, it feels like there is a way there or something, but i can put it in say 3rd gear then back to first and it will go in? any ideas>"??
Zero_chance
1,244
Maricopa, AZ
Dec 11, 2007
  • Dec 11, 2007
Synchros? Does it grind or just not go in at all?
GTA_V6_Mustang
1,326
Miami, FL
Dec 11, 2007
  • Dec 11, 2007
Doesnt sound like synchros to me if it doesnt grind. If you are trying to put it in first and it doesnt let you and you slowly release the clutch while trying to put it in will it go in? Sounds like either a shift fork issue(tabs on shift fork maybe) or a clutch issue.
DDSTANG94
465
FRASER, MICHIGAN
Dec 11, 2007
  • Dec 11, 2007
what is the shift fork??
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Dec 11, 2007
  • Dec 11, 2007
Many times, if you do not depress the clutch pedal all the way to the floor, mine will do this as well. The floor mat on mine slides all over the place, and usually ends up blocking the clutch.
You may also want to pull up on the clutch pedal once, and if it ratchets, then it was likely out of adjustment. Once is enough.
Also, an adjustable clutch quadrant would help.
Scott
HISSIN50
34
129
Dec 11, 2007
  • Dec 11, 2007
How high is your idle set?
GTA_V6_Mustang
1,326
Miami, FL
Dec 12, 2007
  • Dec 12, 2007
Its like a fork missing the middle prong and it is what shifts your synchros from gear to gear. From what I hear, T5 shift forks are prone to bending, lol
DDSTANG94
465
FRASER, MICHIGAN
Dec 12, 2007
  • Dec 12, 2007
it ideals at about 650-750....
DDSTANG94
465
FRASER, MICHIGAN
Dec 12, 2007
  • Dec 12, 2007
ooo got cha!
DDSTANG94
465
FRASER, MICHIGAN
Dec 12, 2007
#10
  • Dec 12, 2007
  • #10
well i just had my mm set up put in......so i know the clutch is realseing al the way now i havent driven it alot so will see how it is now.....
my next ? is there supposed to be a swrew that holds the fwa from moving...cus right now it dosent
HISSIN50
34
129
Dec 12, 2007
#11
  • Dec 12, 2007
  • #11
Yes there is a set screw on most FWA's (if they are not clickers). I set mine initially, then put a mark at 12 o'clock on the adjuster. That way if the clutch starts to feel funny again, I can see if my adjustment walked or if something is happening with hard parts.
Your idle is good. The reason I asked is because sometimes a really low or really high idle makes getting into first consistantly a little tough.
Good luck.
DDSTANG94
465
FRASER, MICHIGAN
Dec 12, 2007
#12
  • Dec 12, 2007
  • #12
Good luck.
there is no set screw in mine...should i b concerned??
WHITE94COBRA
816
HUNTINGTON BEACH
Dec 12, 2007
#13
  • Dec 12, 2007
  • #13
My thoughts exactly, your clutch may be dragging a bit, this is exactly what mine was doing before my clutch swap.
HISSIN50
34
129
Dec 12, 2007
#14
  • Dec 12, 2007
  • #14
I would want some means of locking the adjustment. Some have a set screw, some have a knurled ring that holds the setting, and some are clickers. I dont lock my FWA (because once I do, I cannot get my arms in there to loosen it) and my adjustment walks. I can feel the clutch get 'looser and looser'. I resnug the adjustment when the POE starts heading towards the floor.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 12, 2007
#15
  • Dec 12, 2007
  • #15
I think I'm a little behind the curve on this thread as far as a possible diagnosis, but I don't believe anyone has mentioned the possibility of a bad pilot bearing as another reason for hard shifting into first. Do you have any difficulty hitting first without the engine running? That would likely indicate a clutch engagement issue.
DDSTANG94
465
FRASER, MICHIGAN
Dec 12, 2007
#16
  • Dec 12, 2007
  • #16
yes it does it running and no running
DDSTANG94
465
FRASER, MICHIGAN
Dec 12, 2007
#17
  • Dec 12, 2007
  • #17
thats what i thought..
how much freeplay should there be...
GTA_V6_Mustang
1,326
Miami, FL
Dec 15, 2007
#18
  • Dec 15, 2007
  • #18
Zero Lash,
and a bent shift fork could cause thost same issues as the pilot bearing (giving u trouble putting it in gear even with the car off) Also wouldnt by now the pilot bearing give some related symptoms such as noise?
DDSTANG94
465
FRASER, MICHIGAN
Dec 15, 2007
#19
  • Dec 15, 2007
  • #19
Zero Lash,
and a bent shift fork could cause thost same issues as the pilot bearing (giving u trouble putting it in gear even with the car off) Also wouldn't by now the pilot bearing give some related symptoms such as noise?
ok well i just got my car back, i had a mm cable, fwa, and quad, put on, and also had the fluid changed, it is still NOTCHY going into the gears!!!..this trans is like 3 months old, and it was very smooth when i got it NO NOTCHY gears!!!
the cable is set to about a inch in free play, (the pedal is floppy for like a inch)
GTA_V6_Mustang
1,326
Miami, FL
Dec 15, 2007
#20
  • Dec 15, 2007
  • #20
Where you able to see the condition of the fluid at all? Fluid level? and your FWA should be set at zero lash (no slack)
1 of 2 Next Last
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
9
Unknown engine tick
  • 94 Daily
  • Oct 31, 2025
1994 - 1995 Specific Tech Nov 1, 2025
91AOD5.0LX
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
