  • 2005 - 2009 Specific Tech
First Post: Suspension Kit without lowering
  • Thread starter Thread starter Kato404
  • Start date Start date Feb 26, 2008
K
Kato404
  • Feb 26, 2008
I was wondering if there are any suspension kits available without lowering. I have the Cervini C series body kit(with side pipes) and dont want any lower clearance.
Regards.
LV51FER
318
Caerphilly, Wales, UK
Feb 26, 2008
  • Feb 26, 2008
You can just replace the dampers and keep the stock springs.
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Feb 26, 2008
  • Feb 26, 2008
Get some Tokico D-Spec shocks and struts. They'll let you dial in the firmness and are super easy to adjust. I've got a box sitting here next to me, waiting for better weather to install.
O
o0Dan0o
485
  • Feb 26, 2008
As far as kits... Basically, if you want to replace springs without lowering the car you're going to need an adjustable coil-over kit. Or you can just replace the dampeners like they said.
Dan
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Feb 26, 2008
  • Feb 26, 2008
Also can add stronger aftermarket control arms, panhard bar, subframe connectors, sway bars, shocks, struts... Making the car more responsive and stable while retaining stock height.
anthony05gt
1,262
Maryland
Feb 26, 2008
  • Feb 26, 2008
I'm curious as to why you wouldn't want to at least lower the rear of the car. They sit pretty high in the rear.
DarkFireGT
692
10
89
East Moline, IL
Feb 26, 2008
  • Feb 26, 2008
Definitely. I finally talked my fiance into getting the Roush springs for the rear. Just under an inch of lowering to even it out a bit. That actually will aid in front end clearance, because it'll pull the nose up a bit.
O
o0Dan0o
485
  • Feb 26, 2008
Kool, do you have personal experience with subframe connectors and these cars? I have heard that they don't make much of a difference unless you go with the "through floor" design.
Dan
K
Kato404
  • Feb 27, 2008
Thanks for the replies....I might think about lowering the rear.... but I kinda dont want my pipes scraping more than they already do (Atlanta has alot of hills/bumps/dips in their roadwork)
kooldawg6
Aug 31, 2006
1,679
Central VA
Feb 27, 2008
#10
  • Feb 27, 2008
  • #10
Dan
I have no idea how effective either design is for the S197. All I know is they are available.
anthony05gt
1,262
Maryland
Feb 27, 2008
#11
  • Feb 27, 2008
  • #11
Dan
The new stangs are about 30% stiffer than previous models and don't require subframe connectors until 500-600 rwhp.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
3K
Fox 5.0 Mustang Tech Yesterday at 10:18 AM
jaygee15
J
G
Fox 1989 LX suspension suggestion's
  • Gary97
  • May 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2025
limp
