First time installing Spark plugs.Need help
  • Thread starter Thread starter Greenfive-oh8
  • Start date Start date Jun 5, 2005
1 of 2 Next Last
Greenfive-oh8
30
Fort Lauderdale, FL
Jun 5, 2005
  • Jun 5, 2005
I changed out my spark plugs because i thought it needed new ones, i labeled every stock sparkplug wire that i took off so i knew where to put it back on, i took off the old ones, and put in the new ones, except for two, because i ran out of time and none of the plugs didn't really need changing anyway (they were bosh platinums) and i put in 6 bosch #25's , while i was doing that i deceided i wanted to take off my intake plaque and paint it so i took it off, now when i started up my car the idle was really funky it kept going from like 800 rpm's to like 400 , i knew something was wrong, so i put just the the little bolts back into the intake plaque thinking it was sucking air threw there, the idle became normal again at like 7oo rpms, so i drove my car down the street and i noticed everytime i put the car under acceleration it would spudder and eventually pick up speed while still spudddering untill, i let off the gas or kept it at that speed it would stop. it was like i had the car in higher gear than what is normal. what's going on?
i definately picked the wrong car to do my first tune up on
331 stang91
261
wisconsin
Jun 5, 2005
  • Jun 5, 2005
When you put your plague back on did you maybe damage the gasket or put the gasket on wrong?
sunil6784
620
Boston, MA
Jun 5, 2005
  • Jun 5, 2005
Sounds like the firing order is frigged up...
Did you do all the wires at once ? or one at a time?
Did you take the wires off the distributor cap ?
stang22
1,318
Washington, D.C.
Jun 5, 2005
  • Jun 5, 2005
If you are looking at the distributor cap, you will see a number 1 on it. That is the number one plug wire. In a counter-clockwise motion, your firing order is 13726548. If you are looking at the front of your engine, the first plug of the left side head is plug #1, then straight back, 2,3,4. The first plug on your right side head is plug #5, then 6,7,8. Double check all of your vacuum lines and make sure your plugs are gapped to the correct gap.
Takin the intake plate off to polish/paint it will not affect a single thing. Unless you pulled the entire upper intake off to paint it and botched something up when putting it back on.
Tim
331 stang91
261
wisconsin
Jun 5, 2005
  • Jun 5, 2005
thats what I thought he did took off the upper intake and maybe messed up the gasket or something along those lines.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 5, 2005
  • Jun 5, 2005
I agree with checking the firing order...probably just two mixed up and an easy fix.
BTW -- congrats on your first tune-up.
281pony
2,681
Oly, WA
Jun 5, 2005
  • Jun 5, 2005
so you only swapped 6 of the 8 plugs? did you gap the new spark plugs?
E
emagdnim
391
15
28
Jun 6, 2005
  • Jun 6, 2005
Its definatly a fireing order issue.. trace each wire i had this exact problem .
E
Eric @ DMS
  • Jun 6, 2005
This sounds like a common problem experienced. My initial thought was the firing order as well.
BaXTeR3221
917
Orange County, NY
Jun 6, 2005
#10
  • Jun 6, 2005
  • #10
did the same thing last week, had the same results. Ended up having the 6 and 7 wires on the wrong plugs.
Greenfive-oh8
30
Fort Lauderdale, FL
Jun 6, 2005
#11
  • Jun 6, 2005
  • #11
Thanks for the help, i'm going to go check to see if i put the wrong wire on the wrong plug, while my engine's cold,
oh and to answer your questions
no i did not take off the upper intake just the little plaque on top of it
i did the whole driver side at one time then i did only two on the pass. side
i did not touch the distributor
and i did not gap the new plugs except for one and all the rest looked ok
well ima go get dirty, wish me luck
darthcual
985
Arlington, TX
Jun 6, 2005
#12
  • Jun 6, 2005
  • #12
heres a little tip maybe someone has mentioned b4 but i'll say again change the spark plugs one at a time. Never pull them all off. just unplug one, change the plug, plug it back in. that way there is never a question about firing order. Hope that helps.
*edit i see that u stated in a later post that u did do one at a time but it looked like from the first post u took'em all off sorry for the confusion.
DC
281pony
2,681
Oly, WA
Jun 6, 2005
#13
  • Jun 6, 2005
  • #13
that is why i asked about the gap. its kind of hard to eye thousands of an inch with your eye isint it? having them gapped wrong wont help things either.
cobradvm
245
Woodinville, WA
Jun 6, 2005
#14
  • Jun 6, 2005
  • #14
Yup need to get them gapped - usually at 0.050 of an inch. Also check and make sure none of them cracked - had that happen and the car would stumble under load. Make sure all your connections are okay, and as said above, when changing plugs only do one at a time to make sure the firing order doesn't get messed up.
P
Project89
94
Panama City, Florida
Jun 6, 2005
#15
  • Jun 6, 2005
  • #15
Since you are going to be troubleshooting you should go ahead and replace the two plugs you had originally not replaced.
89lxsport50
550
Franklin Tennessee
Jun 6, 2005
#16
  • Jun 6, 2005
  • #16
Definitely gap your plugs. It is also very easy to damage a spark plug wire by pulling and tugging on it, especially if it is on tight. To get to those 2 plugs on the passenger side remove the air intake hose and undo the smaller emmissions hose that runs above the plugs. The plug nearest the firewall is the hardest to get. Take your time and be careful.
89 Saleen#455
519
New England
Jun 6, 2005
#17
  • Jun 6, 2005
  • #17
Also check the routing of your new spark plug wires. You may have burnt one of your new wires on the exhaust header and its arching out against something metal?
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Jun 6, 2005
#18
  • Jun 6, 2005
  • #18
DC
this is good advice, this method is especially important when changing the wires too.
Greenfive-oh8
30
Fort Lauderdale, FL
Jun 7, 2005
#19
  • Jun 7, 2005
  • #19
my spark plug wires all lead to the right plug, i just triple checked, could not gapping the spark plugs really cause all these problems?
where are the vaccum lines that i should check?
thanks alot , not only are your guys' advice helping me, its giving me some enthusiasm and stopping me from putting a couple fist size dents in my fender
281pony
2,681
Oly, WA
Jun 7, 2005
#20
  • Jun 7, 2005
  • #20
someone just mentioned what i was thinking besides gapping them. did your plug wire get burnt? inspect all the wires, if its arcing on the headers or anything that will cause the symptoms your having.
i re-read your original post and my car did the EXACT same thing from a burnt plug wire. you can get a spark plug gapper for 99 cents and they should be gapped between .052-0.056. i always go for the middle.
good luck.
1 of 2 Next Last
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
