fix running lean?
  • Thread starter Thread starter ninety1gt
  • Start date Start date Nov 11, 2006
ninety1gt
162
san antonio
Nov 11, 2006
  • Nov 11, 2006
i just got back from a dyno day where i put out a whopping 193hp ang 222tq, but at a 15.5-16 air to fuel ratio, they said i can gain up to 30 hp just by bringing down the ratio, so my question is where do i go from here? could my cobra mass air be a problem?? up the fuel pressure?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 11, 2006
  • Nov 11, 2006
Did they happen to check and, or tell you what your fuel pressure was? I'm surprised you're not having detonation issues more than anything.
ninety1gt
162
san antonio
Nov 11, 2006
  • Nov 11, 2006
nope no detenation
vristang
4,933
101
124
Seattle
Nov 12, 2006
  • Nov 12, 2006
I would suspect the Cobra MAF first.
But the first thing you should do is pull your codes. I have a link in my sig if you don't have a scanner.
With the 70mm Cobra MAF you should be using the MAS from a 94-95 Mustang MAF. If you are using the 93 Cobra MAS, or the stock A9* computer MAS, you will have AFR issues.
Post up the 3-4 digit MAS code for your MAF/MAS.
I think the 94-95 Mustang should be F2VF? I am not exactly sure on that though.
jason
Jaswir
578
Orlando, FL
Nov 12, 2006
  • Nov 12, 2006
02 sensor was my cause of running lean... pull the codes and let the computer tell you whats wrong!
check your plugs and see what color they are
ninety1gt
162
san antonio
Nov 12, 2006
  • Nov 12, 2006
i took off the cobra mass and put on my stock meter, it feels like i lost a lil hp but it revs smoother, i was going over the vacuum lines and noticed there is no vac line from the charcoal canister i guess from when i removed the smog pump, do i need to connect it to the vac some how?
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
  • Mindseye007
  • Aug 16, 2026
Mindseye007
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
