Hey guys,
I bought a flame thrower kit and installed it. But it is not working. The problem I am having is that the 1999 mustangs have 8 coil on plugs instead of having just one ignition coil. The instructions say to cut the wire in between the key cylinder and + coil. You are supposed to cut it and connect it to a switch that has 3 inputs. The third input on the switch is for power going to a control box with resistors---> then going to two coil packs I mounted in the trunk----> then to the spark plugs in the tips.
I was a little hesitant to post this because I know a lot of people hate it for various reasons. I would appreciate it if negative opinions were held back. But if you can't hold back thats okay since this is a public forum.
Thank you in advance for any help.
