Flat spot
Hey guys i have a 91 lx 5.0 with a hp draw thru 60mm turbo. It has a 255 fuel pump and 42 lb injectors gt40 heads and intake. When i go from idle to wot its like you turned the key off. I have checked the timing and fuel pressure and its good to go. It had a custom chip so i pulled it out and the spout turned the timing and pressure down and hooked my lm1 up to make sure the afr was correct and its good to go. But to my demise i still have that damn flat spot and its even worse now..............SO PLEASE CAN ANYONE HELP ME OUT.......................THANKS
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
index.php
index.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
