Flipping out Please Help ASAP
NeQX
904
Infront Of You, NY
my stupid BBK AFPR wont go below 44psi no vacuum, screw can go so loose it comes out it just stops going down after 44 its so retarded, its a auto-meter sport comp fp gauge screw in perfectly into shrader valve off a dual fitting 1 going to n2o 1 for gauge, im going to dyno tune car tomorrow before track on sunday please help me get this fuel pressure gauge lower :shrug:
Could be a weak FP regulator that will not hold back the pressure since now your new pump is nice and strong and not very restricted like the clogged one. This is a common issue with many regualtors as they were or get old, it also depends on the gas that is rab through them, some fuel and or additives have more effect of the diaphram.
Ok I figured this crap out finally, fuel pressure worked best at about 50psi even with the 255lph in, they said its due to the C&L cause it leans the car out.............first pull was 255rwhp which means
13.3@102 was with 255rwhp
So, since we changed the plugs which somehow got shot from the old pump going really lean the next pull on dyno was
308.1rwhp
336.8rwtq
Track Sunday! car is cured :owned: :nice:
:flag: :banana: :flag:
