Floor Pan
  • Thread starter Thread starter Saleen781
  • Start date Start date Nov 2, 2006
Saleen781
  • Nov 2, 2006
I have a 92 and the drive side floor pan has tears in it and it sags. Has anyone else had this problem and if so, how much should I expect to spend on getting it welded or replaced?
Jaswir
578
Orlando, FL
Nov 2, 2006
  • Nov 2, 2006
Best bet is to take it to a couple body shops... they might recommand buying a whole new floor pan... 50resto.com has them for around 109 for just the pan...
i have the same problem on my 92 also on the driver side... im gonna try to just get it welded lil cheaper... but im sure it wouldnt cost more then a couple hundred?
i also would like to know how much people have paid to get it done
rd
3,316
63
109
Ocean Springs MS
Nov 2, 2006
  • Nov 2, 2006
Nearly every Fox I have owned has had these cracks. My 79 developed them 15 years ago. I added subframe connectors, and the cracks have not grown a bit since then. I have not actually repaired the cracks.
There are kits and reinforcements to repair this, or you can just do a plain add some metal and weld a repair patch over the crack.
The subframes that have the crossmember that ties to the seat mounting bolts is a good idea also.
bt15
129
Oahu
Nov 2, 2006
  • Nov 2, 2006
Every Fox I've owned has had floorboard cracks - some worse than others. If you have a welder that you can run low power and some rudimentary skill, you can "repair" the cracks at least enough that they won't allow water in the car, creating a foothold for rust. Take your seats and carpet out if you have the inclination (reduces fire hazard and allows access). You will probably scare yourself with how many cracks are there. The only areas with any real strength in your floorboards are the anchor points for the seats and the seatbelts. If you ever do pull your carpet up and inspect the damage, you will almost certainly want to add reinforcement in the form of subframe connectors and seat anchor backing - another job for the welder. If you take it somewhere, you run the risk of them burning your carpet, seats, etc. and the potential for some serious overcharging. If you find a decent place to do the work for you, expect to pay a couple of hundred bucks for the repairs (another reason to consider purchasing a welder if you don't have one, or better yet, borrow it).
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
E
  • Sticky
2003 Mustang GT convertible water leak
  • Eightiesrock1980
  • Jul 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 28, 2026
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
