Flow Tubes
Paul Perreca
1,085
I think i'll need a new set of Flow Tubes due to all the welding on my existing set. I got 2.5 inch spintech Pro Streets coming in the mail, they've been ordered. Now I have a 2.5 inch Off Road H pipe as well... Anyone know where i can order a 2.5 inch set of flow tubes that go from the H pipe to the Mufflers?? Pep Boys does not carry them, and cannot get them in. Doesn't have to be like "name brand" it's just piping... and do you think that I'll need dumps?? (I have H/C/I w/ no tailpipes) (I am planning on welding one side to the muffler, and the other side i beleive thers a "couple" or something that goes to the H....
Thanks!!
Paul Perreca
SeventyMach1 said:
Why do you say that?
Because of the exhaust fumes that fill the car, the exhaust vibrating underneath the car, etc....
The only reason you should have dumps is on a track only car. Unless you can't afford tails. But I don't think that is the case. On a simple street combo like Paul is building it will not net any HP for him so I don't see a need for them. Unless you like being fumigated by your exhaust. :shrug:
well i didnt' have tails or dumps w/ my flowmasters, and the exhaust wasn't like, "THAT" bad, but it was annoying a little bit, and the vibrations were fine, i was just wondering if they would sound stupid coming right out of the muffler, because the flows sounded way better like that, but i have NO experience w/ Spintech Mufflers, but i will be one of the few around here that do once they come in!! YEA countdown has begun for their arrival... thanks guys
Yea, i guess i could have a set made, but 40 bucks isn't that bad for a set of flow tubes.... i may need tailpipes for the muffs to sound right... thanks
Paul Perreca
Paul Perreca said:
what muffler shop do you use?? is it like a branch like meineke or midas or whatever, or is it a small business guy..
I used a local shop.
Just call your local shop and see if they can make them. They should be able to. 2.5 inch tubing is pretty common these days.
