Flowtech Longtube Headers suck!!!
  • Thread starter Thread starter mike7581
  • Start date Start date Oct 7, 2004
mike7581
42
Orange County, CA
Oct 7, 2004
  • Oct 7, 2004
I put on some longtube flowtech headers on my 2.3 - 5.0 swap. i tried to save some money while still buying longtubes so i bought the flowtech longtubes until i had some extra cash to buy better ones. these f-in suck. first of all my starter keeps going out cause it gets to hot. second of all to change the starter i have to lift the motor up a little bit so i can move the header to take out the starter. what a sh--ty design. i guess you get what you pay for here. do not buy these headers they suck. plus you have to cut your k-member to have the driver side header fit correctly which even after that it still doesn't fit snugg without any air leaks. i hate those little psst psst psst sounds. again these headers suck don't buy them.
i am taking suggestions on long tubes with a better design that you have personally used on your car. i understand the heat facter i need to get a heat shield but all the other BS i am not sure if it is worth having long tubes
N
notchman90
87
long isle, ny
Oct 7, 2004
  • Oct 7, 2004
I have mac l/t and i think they are horrible, way too low, install was a pain, and they rub against my steering column. I took off my bbk's cause they were rusted and had about 10 holes. Should have bought another pair. hope this helps
R
raph130
517
  • Oct 7, 2004
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Oct 7, 2004
  • Oct 7, 2004
I had a friend put Flowtech Long Tubes on his Stang After I told him NOT to. He regret's it.....They fit like S**T.
Stick with the phrase, "You Pay For What You Get."
Flowtech is a division of Holley as well as Hooker Headers. Flowtech is Holley's solution to having an affordable header out on the market. Hooker is Holley's premium header line and is quite a bit more money but atleast your getting some quality.
Shon
ram360
2,162
Pennsylvania
Oct 7, 2004
  • Oct 7, 2004
I went w/ mac LT's. I also have the steering shaft rubbing problem. The one tube needs to be heated and bent slightly. It's nothing major but still a flaw in the design. Seem to fit pretty good otherwise. Might try BBK's next time. I've heard a lot of good things about them.
88POSLX
553
Red Deer, AB
Oct 7, 2004
  • Oct 7, 2004
Shon
Goes with the other phrase, "Or else it's shop lifting".
I had the Flowtech longtubes. Didn't have quite the issues you do though. In fact, the only reason I got rid of them is cuz the tube that goes over the steering column had no hope of fitting when I installed my flaming river setup. I did burn through my starter wire a couple times but fixing it took me 30 minutes. Here's a hint, it's a LOT easier taking apart the passenger header than lifting the motor up.
UnderPressureGT
2,285
TR- Jersey Shore
Oct 8, 2004
  • Oct 8, 2004
soo the problem you have is fitment eh? that blows.... You can rule out the starter because thats a common problem with ALL longtubes soo you cant blame that company for blowing out starters. Heck, my equal length headers heat soak my starter as it is.. You HAVE to buy a mini high torque starter,unless you already have one
N
notchman90
87
long isle, ny
Oct 8, 2004
  • Oct 8, 2004
i put a heat wrap around my mini starter and have had no issues.(knock on wood).. try that
BlooDReigN
283
Calgary, Alberta
Oct 8, 2004
  • Oct 8, 2004
I have the problem with the steering shaft rubbing against my tubes aswell. Actually it is bad enough that while turning corners with the car in neutral, the car some times stalls because of the resistance on the pump. Going to get this fixed this week end by grinding down the corners on the shaft that are rubbing.
HardmanGT
500
Thomaston, CT
Oct 8, 2004
#10
  • Oct 8, 2004
  • #10
BBK's here, no problems!
Three_0_Two
54
Warwick, QC
Oct 8, 2004
#11
  • Oct 8, 2004
  • #11
One of my friends has them on his Notch. They were a pain to install. He also had teh rubbing issue with the steering shaft. He dented the headers and looks like it fixed that.
z9_87
332
Urbana, IL
Oct 9, 2004
#12
  • Oct 9, 2004
  • #12
I bought those, and still have them to. When I went to put them on and saw that I needed to cut the k-member, it was over for them. So I got some nice ceramic shorties that fit real nice.
79mustang
253
Tennessee
Oct 9, 2004
#13
  • Oct 9, 2004
  • #13
I've got heddman long tube headers on my car. Didn't have a problem with mine. They were cheap too. I paid 100 bucks for them new. Only thing is they have the 3 bolt 3" collector. You probably don't want that.
later
fly4spd
118
Las Vegas & Reno
Oct 9, 2004
#14
  • Oct 9, 2004
  • #14
i love my bbk ceramics, fit great, light, good power
R
raph130
517
#15
  • Jan 13, 2006
  • #15
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
W
Helpful information for O2 sensors and Longtube headers
  • Warhorse85
  • Aug 16, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 16, 2025
Warhorse85
W
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
  • Mindseye007
  • Aug 16, 2026
Mindseye007
