  • SN95 4.6L Mustang Tech
Fluidyne Radiator With A Procharger?
  • Thread starter Thread starter VIRstang
  • Start date Start date Aug 19, 2012
V
VIRstang
67
Cary, North Carolina
Aug 19, 2012
  • Aug 19, 2012
I recently installed a procharger supercharger on my 99 Mustang GT. At the track, VIR road course, I'm running a steady 236 degrees. So I figure it's time to upgrade the radiator. The fluidyne bolt-in radiator bolted in fine, except for the anti-lock brake module. But once it was mounted there wasn't room to re-install the intake and discharge lines to the supercharger head unit. I had to put hte stcok radiator back in. Will a fluidyne radiator work with a procharger supercharger?
Thanks,
Ben
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 19, 2012
  • Aug 19, 2012
Wouldn't it have been cheaper and more effective to use a diferent thermostat? A flush and some water wetter can't hurt either.
blubullett
535
Modesto, CA
Aug 20, 2012
  • Aug 20, 2012
A thermostat doesn't make your car run cooler. It only makes the minimum operating temp lower. It doesn't make your radiator more efficient. Once the thermostat opens it is up to the radiator to keep the temp as low as possible.
Mattstang04
1,152
144
104
St. Louis, MO
Aug 20, 2012
  • Aug 20, 2012
If the abs module wasn't there would the radiator work with the blower tubing? Or is the radiator size more of the problem?
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
L
Engine What to do now?
  • LATT5133
  • Apr 2, 2021
2K
Fox 5.0 Mustang Tech Apr 4, 2021
Monkeybutt2000
M
Sn95 Compromises
  • imp
  • Oct 12, 2017
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2017
imp
D
Electrical 93 5.0 LX Code 18 SPOUT in Issues
  • DOHCobra
  • Sep 19, 2018
8K
Fox 5.0 Mustang Tech Sep 25, 2024
thinkfaster
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
