  • SN95 4.6L Mustang Tech
Flywheel question
  • Thread starter Thread starter jaboy_x01
  • Start date Start date Apr 6, 2006
J
jaboy_x01
  • Apr 6, 2006
I have an 03 GT. I finally got my misfire problem fixed, but I am in need of a new clutch. I searched on here for a while, and everything I read said get a new flywheel or get your old one resurfaced when you replace the clutch. No problems with that, I just decided to get a new flywheel. I went down today to a performance shop to take a look and see about getting everything installed. 2 of the guys started arguing about which flywheel I needed. 1 was yelling that I needed an 8 bolt, the other was yelling that I needed a 6 bolt because all GTs need a 6 bolt. I have an X for the engine code in my VIN, which is for a windsor engine. Ford even says that windsor engines have and 8 bolt crank.
So am I right that I should have an 8 bolt flywheel?
Thanks
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Apr 6, 2006
  • Apr 6, 2006
Tough question. I'm giving this a bump.
M
mnbf
207
Canada,Saskatoon
Apr 6, 2006
  • Apr 6, 2006
if it is an 03 it should not be a windsor engine... unless that is not the orginal engine that came with the car then you have a romeo engine witch is a 6 bolt flywheel... 99-00 had the windsor engines with the 8 bolt 10.5" clutch yours is 6 bolt 11" clutch also you can count the bolts on the valve cover windsor = 14 bolts romeo = 11 bolts
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Apr 6, 2006
  • Apr 6, 2006
exactly, You should have the Romeo which is 6 bolt. mid 01-04 have the romeo engines. 99-mid 01 have the Windsor. I just went threw this myself a week ago. I original ordered a 8 bolt, took it to ford and they said it did not fit. I had to order a 6 bolt flywheel from mustangtuning next day air because my car was on a lift at ford.. but the 6 bolt was the right one.
stangGT97
1,299
Boston area, MA
Apr 6, 2006
  • Apr 6, 2006
6 bolt for sure, only 99-00 GTs and the Cobras are 8 bolt
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
