I have an 03 GT. I finally got my misfire problem fixed, but I am in need of a new clutch. I searched on here for a while, and everything I read said get a new flywheel or get your old one resurfaced when you replace the clutch. No problems with that, I just decided to get a new flywheel. I went down today to a performance shop to take a look and see about getting everything installed. 2 of the guys started arguing about which flywheel I needed. 1 was yelling that I needed an 8 bolt, the other was yelling that I needed a 6 bolt because all GTs need a 6 bolt. I have an X for the engine code in my VIN, which is for a windsor engine. Ford even says that windsor engines have and 8 bolt crank.
So am I right that I should have an 8 bolt flywheel?
Thanks
Thanks
