Flywheel Selection......
  • Thread starter Thread starter 393_Beast
  • Start date Start date Apr 11, 2007
393_Beast
  • Apr 11, 2007
OK, here is my situation. 393 Stroker with AOD, I want to go with a Tremek, when this engine was built I asked that it be balanced. It is, with the 28oz HB from the original 302. If I want to keep it in balance can someone point me to the clutch, pp, and flywheel I need???
Nibbie
127
  • Apr 11, 2007
well i have had great luck with a centerforce clutch and a fidanza aluminum flywheel. no problems yet.
393_Beast
  • Apr 11, 2007
Actually what I meant was Is there a 28oz flywheel that will bolt up to a windsor crank or not? If there isn't then I should be able to use any windsor flywheel as that is what will be on it now, but if it is possible then do I need to figure out whether I have the 28 or 54 oz now. The car was once a 5spd so there will be no real problem changing it back and I am ready to do it soon. I just need this answered.
Nibbie
127
  • Apr 11, 2007
I think my flywheel came with 2 differnt weights, i know a 28oz and i think a 50 or 54oz weight. it comes with both, you just have to chose one depending on the year of your motor.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
