R Rossafeller New Member Apr 15, 2004 28 0 0 May 23, 2005 #1 May 23, 2005 #1 Does anyone know the torque specs for the 6 bolts that hold the flywheel on?
5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas May 23, 2005 #2 May 23, 2005 #2 90 ft lbs. will do it for ya
Jason 302 10 Year Member Aug 9, 2003 685 71 68 Newark, Ohio May 23, 2005 #3 May 23, 2005 #3 I torque mine to 85 ft-lbs. Make sure you use some loctite. And use enough to seal the threads so they don't leak oil.
R Rossafeller New Member Apr 15, 2004 28 0 0 May 23, 2005 #4 May 23, 2005 #4 thanks alot, i shall be doing this tomorrow
wht93gtEd Active Member Nov 11, 2004 0 9 29 Jersey Shore, New Jersey May 24, 2005 #5 May 24, 2005 #5 yeah, I set my wrench for 90 lb/ft & used some red loctite
