Flywheel torque
  • Thread starter Thread starter NormD
  • Start date Start date Oct 10, 2006
N
NormD
27
  • Oct 10, 2006
Any tips on how to torque flywheel (75 to 85 lbs) properly. In the past it's been difficult for me to properly torque a flywheel since the crank turns as I tighten...... thanks for any tips...... Norm
D
DJCarbine
392
  • Oct 10, 2006
I've always had luck grabbing the flywheel with my left arm, and cranking on it with my right. It also helps if you find the best position to put the most torque on the actual nut, and not the rotation of the flywheel.
1969mach1351
285
Sacramento, CA
Oct 10, 2006
  • Oct 10, 2006
I think what I did was wedge a screwdriver between two of the bolt heads and hold the flywheel from turning.
fasttback
471
Northern CA
Oct 10, 2006
  • Oct 10, 2006
I would run a philips screw driver through one of the open holes on the flywheel and through the open starter hole on the backing plate. As it rotates it will catch the backing plate and stop.
T
The Dan
319
Orange County, CA
Oct 10, 2006
  • Oct 10, 2006
You can buy a flywheel locking tool at the parts store for about $20...saved me A LOT of frustartion and bloody hands.
P
Engine Help 331 stroker
  • pdmount
  • Feb 19, 2026
Fox 5.0 Mustang Tech Feb 21, 2026
pdmount
P
Interior and Upholstery HVAC Mode selector vacuum switch issue.
  • parish99
  • Jul 3, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
KAWMAN2
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
How Many Runs For A Built C-4
  • 93gtmustang
  • Apr 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2025
revhead347
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
