If you like rocks, the c springs will be fine. They are a very high spring rate for the lighter 2.3. In terms of handling, the C-springs will do better than the eibachs. This is simply because the less suspension movement you can get in the front, the better the camber will be. In the mustang suspension, you actaully gain positive camber in suspension compression. It is the opposite of what is ideal for handling.
