FMX to Aod
mcode
51
I would like to know if i can reuse my flywheel and engine block plate ---also will my driveshaft work when i change the yolk to a aod yolk
this is for a 1970 mustang
The flywheel should work, but there may be some difference in the lower edge of the engine rear cover. The FMX uses a 31 spline slip yoke, so you'll have to use one appropriate to the AOD. If the trans is a different length than the FMX, you will need to have the driveshaft altered.
