I have a 70 Mach 1 with a 351W and FMX transmission. Had the whole car apart this winter and working out the bugs at this point. Engine runs great with car in neutral or park. Car runs great driving down the road in any gear. Problem is coming to a stop in gear. Motor will not stay running. Dies like if you don't put in the clutch on a manual transmission car. When sitting in neutral and putting the car in gear it will sound terrible and vibrate alot then finally die. Its like the transmission doesn't slip enough when coming to a stop. What causes this? Is my transmission on its way out? It doesn't slip at all when shifting. Is there a way to adjust this? Theres a vacuum hose going to the trans. What does this do? Does the device the vacuum hose go possibly be shot? You guys have been a great help in trouble shooting other problems in the past Thank you
