fog light wiring question
terr5178
27
88 mustang gt . The fog light dont go on. I checked the bulbs but there is no voltage at the wires. Is there a solonoid that controls the lights after you hit the swith on.
I also have two connectors under the dash to the left of the steering column above the kick panel that are not hooked up to anything. One is a brown clip that has 4 wires. It looks as though a solonoid should go there but I don't know what it controls. The other clip is a long white clip about 3". It also is has no home. Any help diagnoseing the fog light issue and finding a home for the white and brown clips would be appreciated. Thanks
Bad switch or bad wiring, The fox fog light problem is well know. Ford never realy recalled it till it was to late. It's still not a recall but I think they make a wiring kit to fix it. If you haven't put in a relay yet, I would. Ford didn't put big enough gauge wire for them.
Check the fog light fuse too.
Then once you find the issue, do the relay retrofit that others talked about.
Good luck.
