Fog Lights
ok my headlight and parking lights work fine and i did the corral fog light fix and now every time i turn on my fog lights i blow the blade fuse by the battery is there any wires i need to check to see why it keeps blowing fuses. cuz i took out the headlight switch to see if any wires came loose and none were loose. It Just all of a sudden stopped working. and blew the fuse by the battery
Thanks
If the fuse is on the load side of the wiring (terminals 30 or 87), be sure that one leg of the circuit isn't grounded. For instance, if 30 runs to ground and 87 goes to fused battery power, when the relay energizes, it would blow a fuse on the load-side.
