  • 1994 - 1995 Specific Tech
foglights
  • Thread starter Thread starter nickgt5.0
  • Start date Start date Feb 27, 2008
nickgt5.0
96
Snohomish
Feb 27, 2008
  • Feb 27, 2008
is there any way i can wire my lights so when i pull the knob once to have the fogs come on instead of the corners?
94GTCoupe
1,412
92
79
CA
Feb 27, 2008
  • Feb 27, 2008
under center armrest there are two connectors.1 grey for the foglight switch,the other brown for the convertable top.on the brn one,cut the purple/orange wire off and strip the loose end to expose the wire.now on the grey one cut the red/black wire,make sure you leave enough coming out of the connector.now either tape or solder togeather the purple/orange to the red/black wire that is atattched to the grey connector.tape up the end of the loose red/black wire so it does not come into contact with anything.now your fogs will operate independantly of the head/parking lights.the fogs will only operate when the key is in the forward position, turn the fogs on or off at the foglight switch.they will not turn on with the key in the back position.
nickgt5.0
96
Snohomish
Feb 27, 2008
  • Feb 27, 2008
thanks man thats gonna help alot. now i just need the time to do it lol
HISSIN50
34
129
Feb 28, 2008
  • Feb 28, 2008
The brown wire in the headlight switch is the parking light feed. If you powered the fog light switch with this circuit, anytime the parking lights are on, the fogs will be on.
Venom351R
4,548
41
98
MAINE
Feb 28, 2008
  • Feb 28, 2008
There is another way to do it to w/ out splicing wires.
silversmith82
67
Feb 28, 2008
  • Feb 28, 2008
I think he's talking about the foglight switch not the knob...I'm confused.
Anyways to make the SWITCH work independently of the knob yeah you just bug into the convertible power wire. If you don't have a vert top you just swap wires, if you do have a vert top you bug into the power wire so your top still works.
There's a big writeup on both ways to do this on mustangworld. Go look in the tech artices section(not the forums the articles).
94GTCoupe
1,412
92
79
CA
Feb 28, 2008
  • Feb 28, 2008
i have had my fogs as i stated above for well over a year and a half.had no problems whatsoever.it was a clean and simple procedure that i am very happy with.there are many ways to go about reaching the same goal,above was my experiance that i thought nickgt5.0 would find helpful.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Feb 29, 2008
  • Feb 29, 2008
davis3's way is the best way, as you can control the fogs completely independently and even if you leave the switch on, they'll go off with the car.
the vert top wires are also plenty capable of holding the current...
earleys94gt
1,223
Ashley, Ohio
Feb 29, 2008
  • Feb 29, 2008
http://mustangworld.com/ourpics/fcar/fog1.htm
Has picture's if you need some extra help.
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
J
Electrical problem with headlights
  • jeremykrell308
  • Oct 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2025
General karthief
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
