under center armrest there are two connectors.1 grey for the foglight switch,the other brown for the convertable top.on the brn one,cut the purple/orange wire off and strip the loose end to expose the wire.now on the grey one cut the red/black wire,make sure you leave enough coming out of the connector.now either tape or solder togeather the purple/orange to the red/black wire that is atattched to the grey connector.tape up the end of the loose red/black wire so it does not come into contact with anything.now your fogs will operate independantly of the head/parking lights.the fogs will only operate when the key is in the forward position, turn the fogs on or off at the foglight switch.they will not turn on with the key in the back position.
