Thought I'd give you an update for those doing research on a Naturally Aspirated setup with the TrickFlow Specialty 4.6 Twistwed wedge heads. Especially when the knowledge is scarce for these particular heads, even on the web. Had another tuner tweak the car, this time on a Mustang Dyno. The first was on a DynoJet Meter and I wasn't really impressed with the numbers and drivability especially knowing that DynoJet numbers are usually more exaggerative of the truth. It put down 341RWHP and 301TQ The second tune is like night and day. Driviability is way up considering the stg2 cams and it pulled 345RWHP and 297TQ on a tune that is nortorious for displaying low numbers compared to other dyno's. The beast kept pulling. But they stopped at 6500rpms due to the stock internals. The hp never really leveled before that. So theres more to be had. Stock fuel system is still within limits but if I were to go NO2 or Boost of any sort then an upgrade is mandatory not to mention a forged bottom end. Stock throttle body flows more than enough and I'm thinking any bigger wouyld actually cause a loss of vacuum. Also I contemplated going with a larger MAF sensor but after flow test the computer showed that the stock sensor was not pegging but like stated earlier any boost or NO2 would require an upgrade. Its fun to see this little NA 2V pull the way she does. Although she is a work in progress and she is by no means putting down boosted numbers she pulls nicely for the street and occassional strip. Hope this helps any looking at similar setups...oh and she sounds sick on the dyno
-sick2v
-sick2v
