Ford 9" vs 8.8"
  • Thread starter Thread starter Kdubslugga
  • Start date Start date Oct 24, 2010
Kdubslugga
1,515
Akron, OH
Oct 24, 2010
  • Oct 24, 2010
Why are Ford 9" so popular in the Chevy and Mopar world? I would think a nicely built 8.8 with girdle and some 31 spline axles would be just as strong and a helluva lot cheaper. I dunno maybe im wrong, is there any real reason to run a 9" unless you have a 7 second dedicated drag car?
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Oct 24, 2010
  • Oct 24, 2010
Just like the SBC, at one point the Ford 9" was plentiful and cheap. The aftermarket recognized it's durability and versatility, and so started developing modifications for different applications.
By the time the 8.8 came around, the 9" was already king of the mountain. That's just how it works sometimes.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 24, 2010
  • Oct 24, 2010
To change the gear ratios in a 9" rear axle, you remove the axles and then the entire center section of the differential assembly unbolts from the front. If you have several different gear ratios all built up in different center sections, you can change the gearing in 30 minute or less. It's a great option for dirt track and road race cars.
For those of you who would like to know more, see http://www.kevinstang.com/Ninecase.htm
Kdubslugga
1,515
Akron, OH
Oct 24, 2010
  • Oct 24, 2010
Did not know that jrichker! Good stuff!
faststang90
522
baytown texas
Oct 24, 2010
  • Oct 24, 2010
i went from a 8.8 with 35 spline axles to a 9 inch with 40 spline axles,pro gears, a back brace,35 spile input shaft just because i was doing a big motor with a big turbo and i was being told the 8.8 with that size axles had problems so that y i went with a 9 inch. i was told the spools break because there is not alot of metal at the spool. i was going to be making alot of hp
ttopstang
306
Birmingham, AL
Oct 25, 2010
  • Oct 25, 2010
They showed this weekend on extreme 4x4 why the 9 inch was stronger and desired, 1 of the reasons was the ease of gear swaps like jrichker pointed out, the reason it was stronger was the pinion(I think thats what its called) shaft has a bearing at the end after the small gear and it keeps it from lifting under a load.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Oct 26, 2010
  • Oct 26, 2010
the 9" housings they use in the fast drag cars arent the 9inches you guys run on the street anyway. they are fabricated sheet metal housings and is a metric ****ton lighter those old stamped 9" and cast iron 8.8's
faststang90
522
baytown texas
Oct 26, 2010
  • Oct 26, 2010
that is true. my 9 inch you would never see in a factory car. the input on my car is a 35 spline input.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
