  • SN95 4.6L Mustang Tech
Ford fixed clunk
  • Thread starter Thread starter merc123
  • Start date Start date Apr 30, 2004
merc123
420
North GA
Apr 30, 2004
  • Apr 30, 2004
They reported to me that I had driveline slop so they re-indexed the driveshaft and retorqed shaft bolts at rear pinion.
So far there is no clunk.
pony_vert02
285
AUSTIN,TX
Apr 30, 2004
  • Apr 30, 2004
what problem were you having?
LouisianaZJ
237
Apr 30, 2004
  • Apr 30, 2004
what were your symtoms? It sounds like the transmission/driveshaft are about to fall off the stang when I go over bumps. The stealer blew me off ...probably cause I looked to young to have a nice mustang... and told me it was "normal".
If you have a TSB or the mechanics notes/description for this, it would help me out.
merc123
420
North GA
Apr 30, 2004
  • Apr 30, 2004
No TSB's or notes. Just simply they checked the tranny and rear end and found nothing but a lot of driveline slop.
What was happening was when pulling into a parking space or backing up (sometimes) it would make a rubbing/clanking sound almost like leavesprings do when they are screwed up. Someone on here told me differntial clutches but Ford said no. I also had a loud clunk/thud sound when shifting into 1st or 2nd sometimes. Mostly when at a stop it would do it when I put it into 1st. I've been told it was normal but just to be on the safe side I took it in.
I also had the 1-2 grind but since it has only been cold 2 times since I had the car they could't replicate. Said the tranny was fine though.
Here are all of the TSB's from ALL data...
Bulletins for 2003 Ford Mustang V8-281 4.6L SOHC VIN X SFI
Service Bulletins
TSB Number Issue Date TSB Title
03-16-4 AUG 03 Engine - Ticking Noise at Idle
03-15-1 AUG 03 Rear Window Defroster - Inoperative
03-14-8 JUL 03 A/T - Cooler Flushing Service Tips
03-14-4 JUL 03 Ignition System - Engine Misfire Diagnostic Tips
03-11-6 JUN 03 Electrical - Wiring Soldering/Crimping Tips
03-9-8 MAY 03 Emissions - MIL ON/EVAP System DTC's Set
03-8-3 APR 03 Engine - Oil Level Indicator Markings
03-1-5 JAN 03 Interior - Passenger Seat Squeaking Sound
02-23-7 NOV 02 Cooling System - Premium Gold Coolant Service Info
02-23-3 NOV 02 Fuel System - Fuel Pressure Relief Valve Discontinued
02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set
02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check
02-20-8 OCT 02 A/C System - Diagnosis and Service Tips
02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling
1slow03gt
34
jacksonville
Apr 30, 2004
  • Apr 30, 2004
how does one re-index there driveshaft??? mine is doing the same thing(sometimes) now after my gear install
krly79
464
VA Beach & So Illinois
Apr 30, 2004
  • Apr 30, 2004
CBASS
853
Wichita, KS
Apr 30, 2004
  • Apr 30, 2004
It's not always retorqueing the 4 bolts on the DS that will fix it. Ford has loose tolerances in the tranny. Adding LCAs that don't bind and an AL driveshaft will ampliphy the slop. So what some of you hear is normal. Others, it might be a bad DS or loose bolts connecting the DS to the pinion.
merc123
420
North GA
Apr 30, 2004
  • Apr 30, 2004
Not sure how to reindex
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
