Forgot how to adjust headlights...??
  • Thread starter Thread starter cjman15
  • Start date Start date Jun 17, 2005
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 17, 2005
  • Jun 17, 2005
One of my headlights points down to much... how do i adjust it up a little?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 17, 2005
  • Jun 17, 2005
Unbolt the entire assembly, and use some washers on the corners to adjust it the easy way. (you'll need 1 large diameter washer for each corner because the holes are large).. Then just shim it up and reinstall. Took me about 2 tries to get mine all situated.
91ghp5.0
42
Somewhere
Jun 17, 2005
  • Jun 17, 2005
something i will be tryign in the next few days (im installing new headlights in my project car). a friend says the long screw-like studs on the brace behind the headlight can be loosened/tightened to aim them.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 17, 2005
  • Jun 17, 2005
really don't feel like taking them out... haha they can't be adjusted still in the car?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 18, 2005
  • Jun 18, 2005
If you bought Genuine Ford headlights, the adjustment will be easy. If you bought reproduction headlights, they will be very difficult to align properly. I bought reproduction units, and my headlights cannot be aligned: they shine up in the trees and across the road. I even have all 3 screws set up as adjustment screws.
The adjustment screws are upper inside and lower outside screws. If the headlights were re-assembled properly, they will have a 5/32" hex on the screw. You can use a 1/4" ratchet with a 5/32" socket. The upper screws can be reached with the hood up, while the lower screws may require you to lay on the ground in front of the car and reach them from the bottom.
To align the headlights, find a level spot with a wall 25-30 feet away. Disconnect the driver light and align up the passenger light so that the light pattern is slightly below of the actual centerline of the headlight. This is to illuminate the right hand side of the road. Reconnect the driver light and disconnect the passenger light. The driver light should be aimed so that the light pattern on the wall is inward about 6" and slightly below the centerline of the headlight. This keeps you from blinding the oncoming cars. Disconnecting and reconnecting the headlights helps to show which headlight is shining in what direction. Reproduction headlights may shine in several directions at the same time, making it very difficult to align them if both lights are on at the same time.
An alternative to disconnecting thee headlights is to cover one of them with a fender cover while adjusting the other headlight.
I bought new headlight lenses after having the cheapo reproduction models. I spent $5 more per headlight and got the ones with Ford cast into the lens. They seem to align much better than the old reproduction ones did. I just set all 3 screws the same height, and they look like they are aligned pretty good without any more adjusting.
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
