Fouled Plug and Vibrations
  • Thread starter Thread starter onefast65
  • Start date Start date Aug 26, 2006
O
onefast65
45
  • Aug 26, 2006
I have only 1200 miles on the following all new engine:
347 Stroker
SDS Fuel Injection
30LB Steeda Injectors
Trick Flow Track Heat Heads
Custom Victor Intake Manifold
Mac Long Tube Headers
The problem:
I have always noticed a bit of a vibration that shakes the entire care at 2000 - 2500 RMP. Also, I've recently noticed a miss that is causing number 4 plug to turn black in a very short timeframe. Here is what I have tried so far:
1. Replaced rear rigid muffler hangers with flexible type.
2. Replaced spark plugs.
3. Ran engine without belt.
4. Ran engine without belt and crank pully.
5. Reduced fuel pressure to 30 psi.
6. Increase fuel pressure to 50 psi.
7. Switched number 4 injector with number 6.
8. Checked to make sure coil wire is not grounding out on anything.
9. Replaced the coil.
10. Compression tested number 4. Tested 140 to 150 psi dry and wet test.
11. Swapped plug wires 4 and 8.
12. Added rear fuel rail crossover (only had front cross over previously)
13. Swapped injector harness plugs for 3 and 4.
14. Checked valve setting for number 4 - OK.
15. Number 4 rockers appear to be functioning as expected when engine is cranked.
16. Checked rotor phase for SDS system.
17. Checked engine time and advance.
18. Changed engine oil. At same time I swapped 4 plug with a clean one from another cylinder and put a squire of oil into the 4 cylinder.
19. Tried a different distributor cap.
Sorry for the long post but is there anything obvious that I have missed?
O
onefast65
45
  • Aug 27, 2006
Anyone?
OK - I have determined that the problem has to be ignition-related. As I have already swapped my wires from left to right and number 4 plug remains black (and I have changed the coil), I suspect the MSD ignition box. Has anyone seen a failed MSD box result in an engine that runs but with week or intermitent spark. How do I test the box?
One more thing, I have a wideband 02 sensor and as the computer increased air (reduces fuel) the reading increases from 12 to 14.7. As it approaches 14.7 I can feel the engine miss, likely creating a rich exhaust, and then the computers starts over from 12. The cycle repeats.
Any ideas would be greatly appreciated. Just so everyone knows, I will definitely reply to this thread at the end when I actually sort out the problem. I've waisted way too many hours on this problem not to share the solution with others.
91lxttrim
194
AZ
Aug 27, 2006
  • Aug 27, 2006
I went through this:
http://forums.stangnet.com/showthread.php?t=656589&highlight=tick
but now I am having the exact same problem as you. I adjusted the rockers, replaced plug, plug wire, checked dizzy cap, but I swear it's ignition related because the exhaust smells real rich and the number 3 plug that had the loose rocker was fouled. I replaced the plug but it doesn't seem to be fouling again, (only drove around the block) but it is still stumbling at low RPM's.
Could it be a stuck lifter? At this point I'm starting to believe that more than electrical, but how would I be smelling rich exhaust if a stuck lifter would prevent the exhaust valve from opening?
Sorry - I don't mean to hijack the thread but it sounds like we have the exact same problem and I'm dying to resolve this...
ls1beater4eva
334
mooresville
Aug 27, 2006
  • Aug 27, 2006
wow sounds like my problem there only my car is fouling 4 and 7 and every thing but the main harness has been changed.
O
onefast65
45
  • Aug 27, 2006
Hey 91lxttrim.
Thanks for the reply. I adjusted my rockers as well, and watched them function while cranking the engine slowly by hand. I'm thinking that if a lifter was stuck you would have seen this while cranking that cylinder to the top of the compression strock when adjusting the rockers. But you still raise a good question - could a faulty lifter do this? In my case, I have run a compression test and all seems to be ok. But this test is a extremely low rpm. Maybe the exhaust lifter is not functioning at engine speeds. Have you run a compression test on your number 3? When your plug fouls, is it wet or dry when you pull it. Mine is dry and covered in black soot. Mine is bad enough that just idling for a minute or two results in the black plug.
91lxttrim
194
AZ
Aug 27, 2006
  • Aug 27, 2006
My plug was dry but not overly sooty. I felt the same way about the lifter in question, but I adjusted them twice so both times when I went to release the pressure on it, I had to loosen the adjuster all the way because the lifter was decompressing. So I believed it was functioning properly.
I haven't done a compression test yet but I will tonight after it cools down a little. I will let you know tonight what the results are.
O
onefast65
45
  • Aug 28, 2006
I just got off the phone with the shop that helped me design and build the engine. They suspect a possible distributor problem - either the pickup or the ignition module on the outside of the distributor. The bottom line is that I have a custom victor intake manifold that does not give even fuel distribution at low rpm conditions. With the miss, i have not been running the car hard at all. If I can get rid of the miss I will be able to run it hard and see if the fouled plug is just a function of the intake design.
They are going to give me a new distributor to try this evening. I'll post again once I know the results.
91lxttrim
194
AZ
Aug 28, 2006
  • Aug 28, 2006
So have you used that distributor before on another engine? And if so did it just go bad all of a sudden?
O
onefast65
45
  • Aug 28, 2006
Nope - new distributor when I built the engine. I think that this problem was always there, just worse lately. Also, when I installed the wideband last week things looked rather rich so I leaned it out. This made the vibration and miss worse. However, the O2 sensor is installed in my rh header and is likely seeing the results of the fouling number 4 plug. Thus, all other cylinders are now likely running lean. This has caused even more of a miss.
O
onefast65
45
#10
  • Aug 28, 2006
  • #10
New Distributor - still major miss
I replaced the distributor tonight. No change. It is still missing terribly.
91lxttrim
194
AZ
Aug 28, 2006
#11
  • Aug 28, 2006
  • #11
It has got to be a lifter or bent pushrod. I was thinking of switching modules with a buddy but I think in my case it has to be a stuck lifter after what I went through with the ticking.
I still haven't done a compression test (I am tonight), but I don't know what else it could be. Especially since you replaced all the stuff I would have thought of, there's not much left.
ls1beater4eva
334
mooresville
Aug 28, 2006
#12
  • Aug 28, 2006
  • #12
i have changed everything from injectors threw to harnesse's the only thing i havent changed was the main harness im starting to think thats where my problem is it come out of a wrecked car but thats the only thing that hasnt been changed . sorry not trying to highjack this thread just have the similar problems hopefully we can figure this crap out.
:SNSign:
91lxttrim
194
AZ
Aug 28, 2006
#13
  • Aug 28, 2006
  • #13
BTW, just checked my brand new #3 plug and it is fouled BLACK after driving 30 miles. Dead cyl getting fuel and spark - has to be stuck lifter. Right?
Onefast65 - Let's both replace our bad lifters and see what happens. We have the identical problem and between the two of us have ruled everything else out...
O
onefast65
45
#14
  • Aug 28, 2006
  • #14
Compression Test
Here are my compression numbers:
1 = 160psi
2 = 155psi
3 = 155psi
4 = 150psi
5 = 155psi
6 = 155psi
7 = 155psi
8 = 150psi
Let me know what you get. I'm thinking MSD box and then lifters. Not sure that I would get the nice compression numbers above with bad lifters?
Regarding wiring - I re-wired the entire car when I built it. Essentially, the problem has gone from barely noticeable to extremely annoying over 1200 miles. Also, I have never really driven the car too hard - only a few runs through 1st, 2nd and 3rd gears to 6000rpm. It is built pretty strong and should not suffer damage from this.
By the way, a black plug after 30 miles sounds very familiar. Tonight, I found plugs 4, 5 and 8 all to be black.
91lxttrim
194
AZ
Aug 29, 2006
#15
  • Aug 29, 2006
  • #15
Well I just stayed up all night replacing my lifter. Sure enough it runs like a champ now!! Good luck onefast65, and hopefully yours is just the MSD box. If not my money's on the lifter.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 29, 2006
#16
  • Aug 29, 2006
  • #16
Tools needed: Noid light, Mulitmeter (volts & ohms), 10 MM socket & extension, & ratchet.
Note: Do all of the steps and do them in order. The results of the subsequent tests are based on the prior tests being sucessfully passed.
Some basics about the computer:
Remember that the computer does not supply power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
1.) Get a noid light form AutoZone or other auto parts store, or even better a set of them
This set is from http://www.toolking.com/ProductInfo.aspx?productid=12492 and costs $12.
2.) Use the noid light to determine that the injector pulses and isn’t stuck in the on position. It you have a set of them install all of them and compare the pulse intensity. A light that doesn’t pulse and stays on has a short to ground in the computer side of the circuit. That can be either a wiring fault or a failed computer.
If this is the case, remove the passenger side lick panel and disconnect the computer connector. There is one 10 MM bolt holding it in place. Pull the connector all the way out of the computer so that you can see the computer side pins.
Use the list from the graphic below to find the fuel injector pins for the injectors that didn’t turn the noid light off.
3.)
Set the multimeter to low scale Ohms and measure between the computer ground located below the computer and the suspect fuel injector pins. You should see greater than 100 K Ohms resistance. If you see less than 100 Ohms, the wiring between the injector and the computer has a short to ground and needs service. Check the harness and look for damage, kinks or frayed spots.
4.) A light that never turns on is either a wiring fault, or a failed computer. Either the injector has no DC power or the computer has failed and cannot switch the injector circuit to ground. Determine if the injector has power by using the multimeter to check for 12 volts on the red wire on the suspect injector connector. No 12 volts and you have a wiring fault. Check the harness and look for damage, kinks or frayed spots. Check the 10 pin salt & pepper shaker connectors for bent pins, corrosion and damage.
See the graphic for the location of the 10 pin connectors:
See the graphic for the 10 pin connector circuit layout.
Once you have determined that the suspect injectors have good power, the computer is the likely suspect, since a ground is required to complete a circuit and make it function. The computer provides the ground: if doesn’t, then the noid light will not flash.
5.) If you have gotten this far, then the problem is likely ignition related. Remember the noid test using all of the noid lights? All of them were supposed to be equally bright. Since you have already tested all the electrical side of the fuel injector circuit, the one remaining common item is the pip sensor inside the distributor. A failing pip sensor, damaged shutter wheel or bent distributor shaft could all cause the pulse delivered to the injectors to be faulty.
6.) Spark plugs indicate one or more cylinders not firing: use the multimeter to measure the resistance of the spark plug wires. The wires should measure 2000 ohms perfoot of length. A 2 foot wire would be 4000 ohms and a 3 foot wire would be 6000 ohms. Some Taylor and Accel wires have metal cores and will measure much less: that’s OK.
Next examine the spark plug wires very carefully for burn spots, cracks and damaged insulation. One good thing to try is to start the engine while the car is a very dark area, open the hood and look for sparks or blue glow. They indicate the electricity is leaking out of the spark plug wires.
Thanks to Tmoss & Stang&2birds at www.veryuseful.com/mustang/tech/engine/ for some of the graphics
Thanks also to www.fordfuelinjection.com for some of the graphics.
O
onefast65
45
#17
  • Aug 29, 2006
  • #17
Looks like lifters also for me!!
OK, I decided to do one last check for valve adjustment on all cylinders before buying a new MSD box. I got to number 4 cylinder and the exhaust lift offers little to no resistance. I backed it off, and then started turning it down to establish zero lash. Problem is that once I establish zero lash I realized that it took little to no effort to continue turning the nut down. The intake lifter offered good resistance. This would explain a soot covered plug for sure. Looks like lifters for me too! Off to the parts shop I go. At least I found the problem.
I have been sorting this problem out for so long I almost forget what 450 tire-shredding hp feels like. I'll post again once I install new lifters - likely not until next week.
O
onefast65
45
#18
  • Sep 9, 2006
  • #18
Hey 91lxttrim,
I have pulled the intake now and the number 4 intake port is BLACK! However, I see no physical damage to the rockers, rods or lifters. When you changed your bad lifter, was there any way to see that the lifter was bad? Not sure if there is any kind of bench test for this?
91lxttrim
194
AZ
Sep 9, 2006
#19
  • Sep 9, 2006
  • #19
I couldn't tell ny looking at it, but when I went to adjust the rocker, it was loose then immeddiately tight. I don't know if there is any way to test it , I had two extra sets of lifters laying around so I just replaced it.
O
onefast65
45
#20
  • Sep 9, 2006
  • #20
OK Thanks. I have new lifters on order and have high hopes that this is the problem. Thanks for your help. I'll let you know if this solves the problem.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • dan50
  • Jul 18, 2026
dan50
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
